Rear Fog Lamp Installation - Help Guys 😫
24 Mar 2025 20:11 #259893 by jackonlyjack
Only suggested the above because it could be a generic loom/not specific
The gen 3 has connections with nothing in them
24 Mar 2025 20:58 #259894 by fordem
I checked the head light fuses thinking I could just add a circuit to that but the fuses in the engine bay seem to be “live” constantly even with ignition off?
I don't have 4G manuals so I can't be certain, but this is consistent with how Suzuki has wired headlights on most vehicles I have looked at, they fuse the headlights separately and switch the negative, it's done for safety reasons, a failed fuse won't take out both left & right headlights simultaneously.
This diagram comes from an Australian facebook group, I've not attempted to confirm anything.
The following user(s) said Thank You: Alix786
24 Mar 2025 21:15 #259895 by Alix786
Thanks for that @fordem
What I’m hoping to find is a positive ideally under the dash where the other switches are such as the lane assist / headlight washer switch - but the I need the live to be only present when the headlight is on - not the side light only.
Purely because the required standard states that the rear Fog lamp should only come on when the headlights are on.
25 Mar 2025 07:33 #259901 by Alix786
Hi. I would really like to do this procedure myself.
Could you explain what switch the negative means?
Would I not be able to take a feed from the headlight plug for the foglight?
Any advice appreciated
25 Mar 2025 11:11 - 25 Mar 2025 11:12 #259903 by fordem
Based on what you have told us, it is acceptable for the rear fog light(s) to be switched on when the front fog lights are on, irrespective of the headlights, if the car has front fog lights, those should be positive switched.
Negative switching...
The lamp in the first circuit is positively switched, the lamp in the second circuit is negatively switched
Last edit: 25 Mar 2025 11:12 by fordem. Reason: add caption.
06 May 2025 11:18 - 06 May 2025 11:55 #260316 by badshu
Hi I'm importing a Jimny to the UK and it will be arriving soon, and would like to get an idea how did you manage to solve this?
Also I'm struggling to even find a place where to even buy the rear fog lights. Could you point me in the direction?
From looking online the only difference with these required fog lights is to only have one of them on the right hand side of the vehicle?
Last edit: 06 May 2025 11:55 by badshu.
Time to create page: 0.335 seconds
