Rear Fog Lamp Installation - Help Guys 😫
24 Mar 2025 15:29 #259887
by Alix786
Rear Fog Lamp Installation - Help Guys 😫 was created by Alix786
Hello everyone. I’m new to the forum, and I’m in need of some help - there seems to be some real knowledgeable folks on here so fingers crossed.
Back story is; iv recently imported a Gen 4 Suzuki Jimny from Japan and as you will know there is a vigorous test at DVSA it has to undergo in order to obtain a set of number plates.
Now basically I’m trying to fit a rear fog lamp (they don’t come on these from factory)
I need to find a live/positive from the headlight for my switch, so basically a live which only comes on when the headlight is switched on.
has anyone been through this process or can you please advice where I can use a live which only comes on with dipped beam.
Hope that makes sense!
any advice greatly appreciated
24 Mar 2025 16:41 - 24 Mar 2025 16:44 #259888
by fordem
Replied by fordem on topic Rear Fog Lamp Installation - Help Guys 😫
Are you sure you need a live wire from the headlight? The norm is to have the fog lights switch on/off with side or park lights.
Also, which headlights do you have, halogen or LED (I suspect the wiring is different).
Last edit: 24 Mar 2025 16:44 by fordem. Reason: additional question.
24 Mar 2025 17:04 #259889
by Alix786
Replied by Alix786 on topic Rear Fog Lamp Installation - Help Guys 😫
Appreciate the reply.
I have attached the guide - it says it must only come on with dipped beam or main beam or the front foglights,
I can have it working with sidelights but I think it may fail the IVA test as the guide states to only work with dipped beam.
I checked the head light fuses thinking I could just add a circuit to that but the fuses in the engine bay seem to be “live” constantly even with ignition off?
24 Mar 2025 17:07 #259890
by Alix786
Also I believe they are LED / xenon type headlights.
24 Mar 2025 17:43 - 24 Mar 2025 18:12 #259891
Replied by jackonlyjack on topic Rear Fog Lamp Installation - Help Guys 😫
Have you removed the interior trim in the back driver side connector maybe already their also maybe at the dash for a switch
On the gen 3 rear fog wire is green and a black wire into a 2 pin connector
Last edit: 24 Mar 2025 18:12 by jackonlyjack. Reason: Wire colours
24 Mar 2025 19:47 #259892
by Alix786
No because this is a Japanese import they don’t come with a factory fitted rear fog lamp. It has to be fitted before it goes for the test.
I thought someone on here may know where the fuse for headlight or front foglights is so that I could tap into that
Time to create page: 0.239 seconds
