Where to get a load sensing valve bleed screw?
- The Coil Spring
- Senior Member
- Thank you received: 6
28 Feb 2025 12:55 #259628
by The Coil Spring
Replied by The Coil Spring on topic Where to get a load sensing valve bleed screw?
Out of curiosity, which Jimnys had LSPV and why? Seems little useful to me on a Jimny.
- The Coil Spring
- Senior Member
28 Feb 2025 12:59 #259629
by The Coil Spring
Replied by The Coil Spring on topic ECU trouble put a m16a into a 2012 Jimny
Your post has somehow ended up in the wrong thread. Please start a new topic.I’ve bought a 2006 jimny [...] if anyone here has done the engine swap and can give me any advise thanks
28 Feb 2025 13:38 #259630
by fordem
Replied by fordem on topic Where to get a load sensing valve bleed screw?
Non-ABS Jimnys have LSPVs. In ABS equipped Jimnys, the ABS system handles the task of the LSPV.
LSPVs were generally fitted to vehicles where the weight distribution changes as the vehicle is loaded and/or unloaded - the brake bias is changed to decrease rear brake contribution as the load in the vehicle is reduced to reduce the probability of the rear wheels locking up.
You might not think this is needed on a vehicle as small as a Jimny, or with the limited payload of a Jimny, but, take a look at your tyre pressure recommendations, mine is 26F/26R for two persons (presumably both in the front seats) and 26F/29R for four persons (both front & rear seats).
28 Feb 2025 20:22 - 28 Feb 2025 20:26 #259635
by facade
There are two lines in, one from the front circuit, and one from the rear, which then goes out to the rear axle through the valve.
The bleed screw is in the line to the front which otherwise would be a dead end. (You actually don't need to mess with it if you are only playing with the rear brakes as air can't get in from the back, only the front circuit)
As long as there is front brake pressure, the rear pressure is reduced as the axle goes down and pulls the lever. Should the front pressure fail, and the rear brakes are all that is left, then full rear pressure is applied all the time whilst you are praying that the car will stop before it goes over the cliff.
BL FWD cars used to have some strange contrivance with a giant ball bearing inside to do a similar job, they also had a diagonal split baking system at one time too.
ABS cars don't need them as the ABS just cuts off the brake as soon as the wheel starts to lock anyway.
Replied by facade on topic Where to get a load sensing valve bleed screw?
As fordem said, it is on the non-abs Jimnys to prevent rear wheel lock-up (which will cause the back to overtake the front)Out of curiosity, which Jimnys had LSPV and why? Seems little useful to me on a Jimny.
Last edit: 28 Feb 2025 20:26 by facade.
03 Mar 2025 21:01 #259687
by BigKally
Replied by BigKally on topic Where to get a load sensing valve bleed screw?
It'll definitely be a standard thread and size, it's just figuring out what it is that's the hard part. I'm just amazed that someone hasn't worked it out already and that it isn't on the forums or bigjimny wiki anywhere, i'm definitely not the first person to run into this issue.
I ordered a used one that's a bit less round, but it's not a lot better. now i have one to plug up the car with and a spare to play with, I created an abomination, the 17mm bleed nipple. at least it'll snap off before it rounds off.
It's horrible, yes. but it will do the job temporarily it in lieu of a new one.
05 Mar 2025 07:06 #259702
by Motacilla
Replied by Motacilla on topic Where to get a load sensing valve bleed screw?
Next time you visit the local tool shop, pick up a thread gauge. Will save you a lot of time and squinting.It'll definitely be a standard thread and size, it's just figuring out what it is that's the hard part.
Time to create page: 0.338 seconds
