ABS sensor
22 Oct 2024 08:11 #257992 by Motacilla
Replied by Motacilla on topic ABS sensor
Mike, I'm not sure a solder repair is an option with ABS wire. It's been a while since I had one apart, but I seem to recall that the wire and shielding were of a special type due to the tiny currents in the sensor. I may be misremembering but without some careful investigation I would not be confident on a solder repair on this type of sensor.
Wasn't there someone breaking a similar Jimny on here earlier in the summer? Do any of the forum regulars remember that post?
22 Oct 2024 09:02 #257993 by Mike G
Replied by Mike G on topic ABS sensor
Thanks,
I've messaged him, but doesn't look like he's logged on since last year according to his profile. Here's hoping.
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
22 Oct 2024 09:09 #257994 by Mike G
Ah, I think you're right. Looks like I'm stuck with the OEM option, unless I can find a breaker.
Apparently, looking into it, the circuits are sensitive to impedances introduced by soldering. So I'm guessing due to the wires being quite thin, there may be a small error for it being a different length as well.
09 Jul 2025 08:14 #261161 by Geoffrey Ficklebarrow
Replied by Geoffrey Ficklebarrow on topic ABS sensor
Did you ever manage to track down a part number?
Mine has the great honour of being Santana built, so that probably muddies that water terminally!
09 Jul 2025 09:33 #261164 by gv42
Replied by gv42 on topic ABS sensor
Hi yes you can get new ones from Partsinmotion.co.uk had to fit 2
Time to create page: 0.089 seconds
