ABS sensor
20 Oct 2024 20:31 #257970
by Mike G
2" Trailmaster suspension lift, 2"body lift, snorkel, full breather kit, 29" steel wheels with BFG tyres, tinted rear windows, CRT CB radio with modulator antenna mounted on rear, dog cage and tray in the back.
ABS sensor was created by Mike G
Just want to see if anyone else has run into the same issue with sourcing a set of rear ABS sensors for a gen 3 jimny.
All I can see on fleabay and autodoc are the front ABS sensors. Looking specifically for brand new ones. Are they interchangeable? I haven't looked under the car yet as the weather is awful just now.
21 Oct 2024 00:43 #257972
by fordem
Replied by fordem on topic ABS sensor
Try megazip.net
21 Oct 2024 06:50 #257974
by me101
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
Replied by me101 on topic ABS sensor
Hi, had the same issue. Bought a used one from Mr Priestly that sorted it.
21 Oct 2024 11:12 - 21 Oct 2024 11:13 #257975
by Motacilla
Replied by Motacilla on topic ABS sensor
Maybe the next time someone has one in hand, he could post the OEM (Denso? Bosch?) part number here. It is possible that other marques use the same sensor, and knowing the manufacturer's part number -- if it can be found on the part -- might be helpful to those looking in the future.
Last edit: 21 Oct 2024 11:13 by Motacilla.
21 Oct 2024 15:16 #257979
by Mike G
Replied by Mike G on topic ABS sensor
Thanks for the suggestions. The weather was better today. Had a look underneath and found that the sensors are seperate for the rear wheels. Did a bit of fault finding and I definitely have a bad rear right sensor.
Had a look on megazip, but it's only from Japan and expensive. At least for that part.
Couldn't see any other Suzuki motors that used the same sensor and plug combo. Swift iii 05-12 looked like it might fit, bit not sure it would have the length. Could always solder/crimp the old plug on if it won't de-pin. But not sure that's worth a £30 gamble.
Does anyone have the contact for Mr Priestly? Think I'll give him a shout and see what he has.
22 Oct 2024 05:51 #257991
by me101
Message him on here - j999pre . Had a few used parts from him, never an issue. Cheers
