Is extending brake hoses different for a gen3 Jimny with ABS vs without?
10 Sep 2024 10:49 #257498 by Motacilla
As yakuza noted, the front hoses are likely the same. It's the back hoses where you may have a variance.
The HEL kit photo you posted shows a single hose for the rear. This is a typical setup for a sold-rear-axle car with no ABS. However with ABS, you may have a separate circuit for each wheel, which means two hoses for the rear.
The following user(s) said Thank You: RaggieJimny
10 Sep 2024 11:11 #257500 by RaggieJimny
I do remember reading something like that somewhere on a forum but couldn't re-find it haha. I wonder if it's worth getting the lift done, then taking it to a brake specialist afterwards to assess the situation & make custom lines? Someone mentioned that could be quite expensive though - you guys have any leads for alternatives?
Again, really really appreciate your help! Been a long time lurker on this forum
10 Sep 2024 12:58 - 10 Sep 2024 13:00 #257501 by Motacilla
Typically, hydraulic hoses in various lengths with appropriate connectors are available off the shelf -- there probably is no need to have them custom-made. Worth talking to your brake specialist before you dive in, though, if only to save time during the fit-out.
Note when talking to the brake man that often specialists will use the word "lines" to refer only to the steel or alloy (hard) lines in the system, and will say "hoses" for the flexible sections.  Just FYI for when you are having those discussions.
Last edit: 10 Sep 2024 13:00 by Motacilla.
10 Sep 2024 17:17 #257502 by Lambert
I got mine from a member on here. They were extended but I wasn't after that so much as them being braided and therefore stronger and better pedal feel. My 2011 had one rear line even with abs but my current very late gen3 has 2 at the back as it has traction control so has to be able to fire each brake separately
10 Sep 2024 19:47 #257503 by The Coil Spring
There is a real possibility that you might wreck some of the brake pipes because of seized and rusty connections. The motor factors in my area cut brake pipes to length from a huge roll and install the end nipples, which is not expensive. Then I use a pipe bending tool to bend the them into shape. Ask for cut-offs to practice your bending.
Time to create page: 0.226 seconds
