Auto/Manual Transfer Case and Diff Ratio Differences
05 Aug 2024 21:51 #257099
by Youngkelv
Auto/Manual Transfer Case and Diff Ratio Differences was created by Youngkelv
Hi all,
I’ve pretty much finished my Jimny rebuild project which involved rebuilding a rolled 2005 Auto Jimny by canibalising a rolled and unrepairable 2012 manual Jimny. Unfortunately I’m have issues with auto trans on the 05 and are contemplating a manual swap using the 2012 drivetrain. 2 Questions if anyone can help… 1. Are the diff head ratios the same on both vehicles? (I’m thinking not) and 2. Are the transfer case ratios the Same? Any knowledge on this would be much appreciated! Cheers!
05 Aug 2024 22:06 #257101
Replied by yakuza on topic Auto/Manual Transfer Case and Diff Ratio Differences
Transfer case ratios are way different.
Diff ratios also to make up for the the other ratios.
Unless you plan to change tyre size you should keep all from either manual or auto.
www.bigjimny.com/mediawiki/index.php/Tra...ssion_gearing_ratios
06 Aug 2024 08:48 #257110
by Youngkelv
Replied by Youngkelv on topic Auto/Manual Transfer Case and Diff Ratio Differences
Thanks for that! very much appreciated. this is a great website. Makes sense although I wonder if I just replace gear box and see what sort of ratios I get then go from there? ie then change transfer box then diffs if required. Just a thought as I have everything required...
06 Aug 2024 14:43 #257112
by Busta
Replied by Busta on topic Auto/Manual Transfer Case and Diff Ratio Differences
If the 2005 is also a VVT then diff ratios will be the same but the auto transfer case will be 30% lower than the 2012 manual one.
