CEL and rough idle
08 Jul 2024 18:44 #256695 by Bennyb7
CEL and rough idle was created by Bennyb7
Hi friends,
has anyone with a K6a jimny experienced the following:
On starting, the engine runs smoothly around 1500rpm. Then, after about 2 seconds the engine shutters, bogs down to 600rpm, a check engine light illuminates, then it immediately corrects to a rough idle around 1300rpm with the check engine light remaining on.
I know its a long shot but im hoping someone can point me in the right direction.
thanks for reading!
08 Jul 2024 20:07 #256696 by fordem
Replied by fordem on topic CEL and rough idle
The check engine light will point you in the right direction - get the code(s) read.
08 Jul 2024 22:04 #256697 by Bennyb7
Replied by Bennyb7 on topic CEL and rough idle
It's a 1996 and I can't find a code reader that can communicate with it. Do you have any suggestions for code readers?
08 Jul 2024 22:17 #256698 by fordem
Launch X431 will have something that can.
09 Jul 2024 03:18 #256699 by Lambert
Replied by Lambert on topic CEL and rough idle
Alternatively in the wiki section are instructions on how to get a flash code by bridging the pins on the port.
09 Jul 2024 19:01 #256706 by Bennyb7
First off, thank you immensely for the reply. I read through the wiki and it was helpful. My understanding so far is that I need to
1) buy transponder (will have to research unless you can reccomend one)
2) download that kind russian programmers app
3) bridge the diag fuse or two pins on the OBD connector
4) enjoy having some diagnostics displayed in the app
Am I missing anything important?
Time to create page: 0.193 seconds
