Radiator fan removal
20 May 2024 11:06 #256010
by me101
2007 Little Jim with cheap mods!
www.youtube.com/channel/UCeBDekO99Qk2aOmBmSmrI9w
Radiator fan removal was created by me101
Hi, just a quick one. The rad fan on my 2007 is not working correctly. Not sure how long it has been this way, never had an overheat problem in the last 6 years, but when pulling the trailer up hills the other day (motorway), temp climbed quite high, then dropped when not having to work as hard. Fan spins freely when engine is cold and hot, so assuming the coupling is seized and not adjusting to the heat? Can this be replaced without removing the radiator itself?
Cheers
Cheers
- Thank you received: 679
20 May 2024 12:36 #256011
Replied by DrRobin on topic Radiator fan removal
Yes. I took the fan off mine when I changed the fan belt pulley, it needs a bit of a jiggle to get the cowling off but it is fairly straight forward. I think there might be a guide somewhere, possibly on BigJimny.
To be honest the radiator is very to take out once the fan is off, it's just drain it (plug at the bottom), remove top and bottom pipes (the hardest part) then it's held in on 2 or 3 bolts. Depending on how good you are removing the self tensioning hose clips it's just a few minutes work.
Robin
Robin
20 May 2024 12:39 #256012
by me101
Replied by me101 on topic Radiator fan removal
Thanks. Can you remember if the bolts were on the back of the fan? Forgot to look yesterday. Also - radio now fitted and working well thanks!
20 May 2024 12:54 #256013
I can't remember to be honest, it was about 3 years ago.
I am glad the radio is fitted and working well, any problems or Qs, you know where I am.
Robin
Robin
- Thank you received: 2004
20 May 2024 18:13 #256015
Replied by Lambert on topic Radiator fan removal
It is possible to split the fan clutch and top off the silicon oil. It's the same as used in radio control models suspension I think I used 1000 spec.
21 May 2024 06:12 #256024
by me101
Thanks, I'll have a look.
Time to create page: 0.099 seconds
