Does the M13A jimny have an EGR system?
20 Apr 2024 17:39 #255700 by Vandoni
The little pipe I'm talking about is the one you can see in the picture to the right of the rightmost runner , right now I'm not home so I can't check the evap system
20 Apr 2024 18:22 #255701 by fordem
That little pipe IS part of the EGR feed and I'll bet that if you check the other side as suggested, you WILL find the EGR valve.
21 Apr 2024 00:23 #255705 by Vandoni
Ok thanks for the clarification, I was thinking of either cleaning the valve or doing an EGR delete, I still have to choose what to do though
21 Apr 2024 02:14 #255706 by fordem
What are you hoping to achieve?
21 Apr 2024 13:56 #255714 by Vandoni
Well I don't quite know, I'm trying to inform myself a little more to see if it's useful or not
21 Apr 2024 19:24 #255720 by fordem
First - depending on where you are tampering with the emission systems can be illegal.
That aside, most newer vehicles monitor EGR flow and will generate check engine codes if the flow is not what is expected, an 'EGR Delete" would need to remove these checks from the ECU software.
Non-functional EGR systems reduce carbon buildup in the intake, but increase combustion chamber temperatures and with it, the production of pollutants, primarily oxides of nitrogen. Engine damage (burned exhaust valves) is a possible outcome.
Time to create page: 1.447 seconds
