Warning yellow lights all lit, including "steering wheel!"
18 Mar 2024 09:17 #255136 by DrRobin
All of the warning lights apart from the lane warning are linked, the brakes, steering ESP etc, so it could be one thing that is throwing it out.
I would think that ESP used the wheel speed sensor (ABS sensor), but there might be others which are used.
Certainly when my other car had a ABS sensor on the way out, it gave an error code on the OBD.
Perhaps the ESP/ABS just needs a reset? Martin would most likely know.
Robin
18 Mar 2024 11:26 #255138 by Soeley
Have you tried putting the std panhard back on to see if the lights go off?
18 Mar 2024 17:28 - 18 Mar 2024 17:49 #255143 by Filipao
Yes, did it immediately to no avail...
Thank you Hughes, Motacilla, Dr. Robin and Soeley!
Last edit: 18 Mar 2024 17:49 by Filipao.
18 Mar 2024 21:24 - 18 Mar 2024 21:31 #255152 by Soeley
Absolutely right, sorry, here they are.
In your pictures, the Coolant temp Blue light and seatbelt warning light are on. Are they part of the problem or just because the engine was was cold and no seatbelt on when you took the pictures?
Edit: And the Handbrake warning as well?
Last edit: 18 Mar 2024 21:31 by Soeley.
18 Mar 2024 22:30 #255156 by DrRobin
The speedo is zero, so vehicle not moving. Chances are the photo was taken soon after start up and in the garage.
Robin
18 Mar 2024 23:43 #255161 by Hughes
I think motacilla is right. Something needs recalibrating after the drive with the steering wheel on the turps.
Tried turning the wheel lock to lock and cycling the key?
May have be a dealer reset jobbie.
Definitely let us know what fixed it.
Time to create page: 0.255 seconds
