HIGH IDLE SPEED PROBLEM NOW.
- greenmachine
Topic Author
- Senior Member
- Thank you received: 5
05 Mar 2024 19:24 #254838
by greenmachine
HIGH IDLE SPEED PROBLEM NOW. was created by greenmachine
shes up and running after ECU , column, and coil swap but is idling at 2000rpm? the engine is a swift 1.6 i swapped out 5 yrs ago, i cant adjust the throttle cable any as its slack. any ideas why it is or how i can get idle down? cheers L
- Thank you received: 2005
06 Mar 2024 04:21 #254843
Replied by Lambert on topic HIGH IDLE SPEED PROBLEM NOW.
Check for a vacuum leak.
- greenmachine
Topic Author
- Senior Member
06 Mar 2024 13:43 - 06 Mar 2024 13:53 #254859
by greenmachine
Replied by greenmachine on topic HIGH IDLE SPEED PROBLEM NOW.
Cheers Lambert, what vac hose you thinking? , I checked the PSV on the back left of the rocker cover, and it seems to be fine (it actuates when i put my finger over when running) i read here that the AIC valve on the side of the throttle body can be the problem? ive a much cleaner one on my donor car i could swap. would that be a next step? shes in for an MOT today so i,m hoping that wont be rotton beyond test.
Last edit: 06 Mar 2024 13:53 by greenmachine.
06 Mar 2024 18:43 #254865
Replied by jackonlyjack on topic HIGH IDLE SPEED PROBLEM NOW.
Did you try the cross head screw with the lock nut
That's how I sorted my revs when I fitted liana throttle body
- greenmachine
Topic Author
- Senior Member
08 Mar 2024 11:22 #254906
by greenmachine
hey Jack, you mean an adjuster jet on the throttle body? ive a picture but dont know how to add here,. i see 4 x 13mm bolts holding the throttle body down, i was going to take those out and swap the lot. wish i could attach picture!
worse prob is failed drastically on rot of cab to chassic. arrgghh , new thread for that!
08 Mar 2024 15:23 #254921
