Tips for changing gearbox and transfer box oil needed
- Thank you received: 1982
11 Feb 2024 03:43 #254212
Replied by Lambert on topic Tips for changing gearbox and transfer box oil needed
It's all in the jimny information section in the top banner.
- rogerzilla
11 Feb 2024 07:17 #254214
by rogerzilla
Replied by rogerzilla on topic Tips for changing gearbox and transfer box oil needed
The no.1 tip is not to undo the drain plug before ensuring the filler plug can also be undone.
Also, when undoing the filler plug on the transfer box using the 10mm square key, the end of a ratchet driver is very close to the propshaft UJ. If it makes contact, you may have trouble reversing the ratchet to free it. Best to loosen the plug using the square key, then use a 3/4 drive ratchet with no attachment to finish taking it out.
11 Feb 2024 08:39 #254218
3/8th not 3/4 drive.
11 Feb 2024 09:17 #254221
Replied by mlines on topic Tips for changing gearbox and transfer box oil needed
I have a little pump that screws into the cap of a standard oil bottle. However it is best to warm the oil bottle in the airing cupboard for a few hours before.
Similar to this but I recall only pay a tenner for mine
www.amazon.co.uk/SANCAK-Marine-Accessory...earbox/dp/B0CN6ZTQ99
The following user(s) said Thank You: robs5230
- rogerzilla
11 Feb 2024 09:31 #254224
by rogerzilla
Oops! Yes, 3/8" drive. The middle sized one!
- Thank you received: 77
11 Feb 2024 16:35 #254229
by robs5230
standard jimny - for now
Replied by robs5230 on topic Tips for changing gearbox and transfer box oil needed
Cheers
After what seemed like ages I have now found it
Time to create page: 0.204 seconds
