Tips for changing gearbox and transfer box oil needed
- Thank you received: 77
11 Feb 2024 16:36 #254230
by robs5230
standard jimny - for now
Replied by robs5230 on topic Tips for changing gearbox and transfer box oil needed
Yep.
Remembered that from last time and also ordered a 10mm key from Martin
11 Feb 2024 17:30 #254231
by Phaeton
Replied by Phaeton on topic Tips for changing gearbox and transfer box oil needed
This is the best advice you will ever received, take it from somebody who had to help his friend take out a gearbox out because he drained it & the filler was so damaged it was only when on the bench with a chisel could we get it to move.The no.1 tip is not to undo the drain plug before ensuring the filler plug can also be undone.
The following user(s) said Thank You: robs5230
11 Feb 2024 19:54 #254234
by robs5230
Picked the oils up this afternoon so planning on doing it Friday
16 Feb 2024 11:52 - 16 Feb 2024 11:53 #254372
by robs5230
Well
I finally got round to doing this job today, which turned out to be a bit more hassle than I remembered, from the last time I did it.
My last Jimny had a 3" lift as well as running 195/80 tyres, so on standard sized AT tyres and suspension, there simply wasn't enough working room under the vehicle (or I've grown, which is highly possible).
Ended up raising the rear on a set of ramps, then jacking to support the front on axle stands.
The oil that came out was rather less clear than the new stuff, but no metal deposits anywhere on the drain plug.
The filler plug on the gearbox was particularly tight, but gave with enough force.
The pump, certainly made getting the oil in easier, but is a very labour intensive job and got it done.
The 10mm key ordered from Martin, wouldn't fit either the fill or drain plugs on the boxes (neither was there enough access on the gearbox filler anyway, but the 3/8 end of a Teng ratchet fitted snugly enough, so used that.
A short run, sees the gearbox sounding quieter, which is nice, and it will get a longer run later to fully evaluate.
Last edit: 16 Feb 2024 11:53 by robs5230.
- rogerzilla
16 Feb 2024 14:02 #254375
by rogerzilla
Replied by rogerzilla on topic Tips for changing gearbox and transfer box oil needed
The 10mm key only fits a new clean plug. I bought new plugs and put them back in with the key. To prevent new plugs rusting, smear them with high temperature waterproof grease like Ceratec. Vaseline will melt and run off, because the diffs (ok, normally only the rear one) get quite hot.
Time to create page: 0.524 seconds
