Jimny VVT less power at low revs than non-VVT?
04 Feb 2024 21:16 - 04 Feb 2024 21:19 #254028
by tomlil01
Jimny VVT less power at low revs than non-VVT? was created by tomlil01
Hi, all,
I don't know much about power and torque and gear ratios, so perhaps a stupid question.
I have a 2005 VVT Jimny with 235/75/R15 tyres and my friend who has the same tyres on his non-VVT drove my car the other day and said it felt like it was down on power. I have 17% reduction gears (high range) in my car and he does not, so I would expect my car to feel better (also VVT is supposed to have slightly more BHP).
I have a fairly steep hill near where I live and when I'm going up at ~3k revs in fourth gear at about 40mph, I can't accelerate without dropping down a gear.
I'm trying to understand, is the VVT more likely to get "stuck" in low-power/economy mode (with less fuel and air), and be unable to increase RPM (forcing you to drop down a gear) compared to a non-VVT (operating at full power all the time)?
i e.- the VVT is operating with less power than the non-VVT until the revs are up to ~4k(?), and with the big tyres, going up hill, I can't get the revs up to that band.
Or am I totally misunderstanding something?
Thanks in advance
Lee
Thanks in advance
Lee
Last edit: 04 Feb 2024 21:19 by tomlil01.
04 Feb 2024 23:23 - 04 Feb 2024 23:25 #254029
Replied by yakuza on topic Jimny VVT less power at low revs than non-VVT?
I think that compared to the tyres and gearing the VVT should not be noticable.
Having driven one VVT alot with 17% and 235 's and a mates non vvt with 215 and no gearing change, I would say they where pretty similar, both m16.
How ever, my vvt with broken catalytic converters was pretty slow. Cat no 1 disintegrates and clogs up cat no 2.
Last edit: 04 Feb 2024 23:25 by yakuza.
05 Feb 2024 09:58 #254033
by tomlil01
Replied by tomlil01 on topic Jimny VVT less power at low revs than non-VVT?
Thanks, yakuza. Although my friend has the same 235 tyres as me and says my car feels underpowered. We both have 1.3 engines, so the only difference I could imagine was that mine is VVT.
I would have expected that my 17% gears should make my car better able to power up hills with low-ish revs, not worse. So I am trying to understand whether it is the VVT that makes the car feel underpowered until the revs get higher, compared to my friend's non-VVT. My rough understanding is that the VVT effectively reduces power output at lower revs e.g. for fuel consumption etc.
Thanks
Lee
Thanks
Lee
- rogerzilla
05 Feb 2024 10:28 #254034
by rogerzilla
Replied by rogerzilla on topic Jimny VVT less power at low revs than non-VVT?
In theory VVT increases power and torque by allowing more valve overlap at high revs. If the cams were set for a lot of overlap without VVT, the engine would be unable to idle at low revs. However, manufacturers may use it for other purposes, such as emissions control.
- Thank you received: 663
05 Feb 2024 10:33 #254035
Replied by DrRobin on topic Jimny VVT less power at low revs than non-VVT?
VVT is designed to spread the torque and power over a wider rev range by flattening the torque curve and is generally more effective at the mid to higher revs. There is probably very little difference in the lower revs. If the VVT and non-VVT produce the same amount of torque at lower revs and the vehicle speed is the similar (you might be using a higher gear?), then they will feel the same.
The point of using a 17% reduction in gearing is to compensate for the bigger tyres so you can get the engine spinning in the torque and power band (>3,000 rpm), not slugging around at 2,000 rpm.
However, agreed it shouldn't be worse, but I doubt that is the fault of VVT, more likely to be something else.
05 Feb 2024 12:15 - 05 Feb 2024 12:16 #254036
by 300bhpton
Most of the systems allow an engine to run essentially different cam profiles at low rpm vs high rpm. This however is almost entirely done for emissions reasons and to a lesser extent improved drivability down low.
On nearly every engine using this kind of tech, switching to the more aggressive profile will nearly always improve power and performance everywhere which is what a lot of remaps do.
As for your vehicle. I'd say yes the gear reduction should help. But you'd need to see a dyno plot of a VVT and non VVT engine to see if there is any difference in power/torque for a given rpm.
Subjective feel is not very accurate. Ways you can measure would be to use an app on your smartphone. Or even just a GPS speed readout and a stop watch. Don't do a standing start, just measure acceleration over a set range, ideally in a single gear. Such as 30-50mph roll. Then get your friend to do the same on the same road.
The other way to measure would be line both cars up side by side and do a roll race from a set speed. It will be very clear to see if one is faster than the other.
Replied by 300bhpton on topic Jimny VVT less power at low revs than non-VVT?
Well no, that isn't how VVT works. I'm not exactly sure how the Suzuki version works, although most car makers have offered something similar. Earlier examples being the Honda VTEC and Rover VVC engines. The main difference here being the Rover's was continuously variable while the Honda was more of a stepped approach.Hi, all,
Thanks in advance
Lee
Last edit: 05 Feb 2024 12:16 by 300bhpton.
Time to create page: 0.205 seconds
