Technical Tyre Question
07 Dec 2023 20:25 #252713 by Soeley
Replied by Soeley on topic Technical Tyre Question
Definitely a tread wear bar, never seen one set at 4mm before, but never had proper AT tyres. Maybe Google the tyre & see what the manufacturer says,
Yeah thanks, tried that, but all it came up with was your normal side wall markings.
07 Dec 2023 20:26 #252714 by Soeley
If you look on the side wall a small triangle with twi printed under it
Tread wear indicator
Never seen the other indicator circled in red
When my tyres get to around 8mm they get changed
Only really used off road
Thanks, I'll have a look tomorrow.
08 Dec 2023 10:30 #252727 by Roger Fairclough
My standard Dueler tyres have these and they indicate 3mm tread left so I assume that is a common sense ( change me if you know what's good for you) as against the legal limit marker ( change me you idiot ) of 1.6mm.
Roger
08 Dec 2023 10:41 #252728 by yakuza
Replied by yakuza on topic Technical Tyre Question
Here in Norway the limit for tyres during winter is 3mm.
I f this tyre is also sold here with an three peak snow flake marking, then that might be an explanation.
Should be min. 3mm all year in my opinion so Rogers interpretations are good guidelines.
