Technical Tyre Question
- Thank you received: 578
07 Dec 2023 13:57 - 07 Dec 2023 13:58 #252696
Technical Tyre Question was created by Soeley
What is the Marker circled in red, it is the first time I have spotted that one and presuming the bumps circled in yellow are the depth wear markers.
The tyres do have 5.5 to 6.0mm of tread left on them.
Last edit: 07 Dec 2023 13:58 by Soeley.
07 Dec 2023 15:07 #252699
by 300bhpton
Replied by 300bhpton on topic Technical Tyre Question
07 Dec 2023 16:13 #252702
Replied by Soeley on topic Technical Tyre Question
The one circled in red would leave about 4mm of thread depth. Could it be an 'Off Road' tread wear indicator? Obviously for off road use you don't really want to get down to 1.6mm. So do AT tyres have two wear marker indicators, one for minimum road legal limit and one for minimum off road grip/performance?
07 Dec 2023 16:31 #252704
by Phaeton
Replied by Phaeton on topic Technical Tyre Question
Definitely a tread wear bar, never seen one set at 4mm before, but never had proper AT tyres. Maybe Google the tyre & see what the manufacturer says,
07 Dec 2023 17:44 #252706
by fordem
This has been, so to speak, my experience and my assumption.
Over a couple of decades and a half dozen or so different brands of AT tires, I've noticed what appears to be two sets of wear bars, and I've assumed, that the taller one is for off road usage.
Replied by fordem on topic Technical Tyre Question
- Thank you received: 706
07 Dec 2023 18:52 #252709
Replied by jackonlyjack on topic Technical Tyre Question
If you look on the side wall a small triangle with twi printed under it
Tread wear indicator
Never seen the other indicator circled in red
When my tyres get to around 8mm they get changed
Only really used off road
Time to create page: 0.682 seconds
