Battery size - 054 or 057?
  • rogerzilla
03 Oct 2023 14:54 - 03 Oct 2023 15:02 #251161 by rogerzilla
Battery size - 054 or 057? was created by rogerzilla
057 is what's in the car.  054 is what most sources recommend but the terminals would be the wrong way around - every Jimny I've seen has +ve at bottom right, looking at it with the bonnet open.  What's correct?  057 is the right orientation and has JIS terminals, but is a bigger battery.
Car is a gen3 M13A auto.
Last edit: 03 Oct 2023 15:02 by rogerzilla.
03 Oct 2023 15:52 #251163 by Scimike
Replied by Scimike on topic Battery size - 054 or 057?
I've just fitted a HB057. Universal terminals (remove std terminal to expose JIS).
2009 Manual, works and fits fine
03 Oct 2023 15:58 #251164 by DrRobin
Replied by DrRobin on topic Battery size - 054 or 057?
The wiki and most websites list 054 as the correct battery, but as you say the terminals are the wrong way round.
I changed mine a couple of years ago, it has a 155 in. I took a Yuasa out (probably original battery), but it doesn't have a code on it and the battery terminals are the same way around as the 155, no need to re-wire.
The one I took out can't be a 054, the terminals are the wrong way around.
A 155 is 45AHr compared to the 35 or 40AHr for the other batteries.
Robin
03 Oct 2023 17:11 #251168 by Busta
Replied by Busta on topic Battery size - 054 or 057?
A Yuasa 5057 is about the best battery you can fit in the standard tray. 50ah, 450a and not too expensive either.
03 Oct 2023 17:50 - 03 Oct 2023 18:17 #251169 by Scimike
The next step down the Yuasa tree is the YBX3057, 45AH and 400CCA.
That's the same battery that Halfords sell as HB057, Yuasa make Halfords batteries, or at least they did when I worked for them. Very cheap with a Halfords trade card and just down the road with a no quibble warranty.
I believe the one I removed was a Bosch 155 (B33), nothing wrong with that, it was just old and needed changing. Same footprint as all the others mentioned. The 054 has the terminals the other way, +ve near bulkhead in my photo.
So the correct battery is the one that physically fits, any of the above, balanced against how much you want to spend. Generally more Ah is a good thing if you can get it.
Last edit: 03 Oct 2023 18:17 by Scimike.
  • rogerzilla
03 Oct 2023 20:40 #251171 by rogerzilla
Replied by rogerzilla on topic Battery size - 054 or 057?
Thanks all.  Some suppliers do say 057 is correct but 054 seems to be in the majority, even if it's not right!
Time to create page: 0.106 seconds
