Coolant vapor though air con exits
30 Jul 2023 16:49 #250050 by Lambert
Don't disturb those they are the refrigerant lines and contain gases that are bad for you and the environment. The ones you want are on the bulkhead and feed the heater matrix. I'm still at work or I would photo them for you.
The following user(s) said Thank You: jcvs17cr
30 Jul 2023 17:33 #250052 by jcvs17cr
If you can send me a photo later I would appreciate it
30 Jul 2023 19:04 #250055 by jcvs17cr
I think I found the hoses that you are referring to. I'm guessing these should be loop at the engine side. If so would it be possible that the top hose can reach the engine exit of the bottom hose? Or will I definitely need a pipe to connect both?
[img
31 Jul 2023 03:20 #250057 by Lambert
Those are they. I can't remember if they are long enough but it's worth trying.
Time to create page: 0.182 seconds
