Coolant vapor though air con exits
30 Jul 2023 01:43 #250036
by jcvs17cr
Coolant vapor though air con exits was created by jcvs17cr
Hi,
Yesterday I had a long trip. Today when I started the car, as soon as it got to normal temp, a lot of vapor started coming out of the air conditioning exits in the cabin (I rarely use the air con and I wasnt using it when it started) and this vapor has a "sweet" smell to it, which I think is the coolant. Any quick fix to avoid inhaling this (probably toxic) vapor all the way home.
It seems it was definitely coolant as when checking the radiator, it was missing around 1 liter of coolant. Thankfully the car wasn't overheating.
I was thinking .maybe there is a way to avoid the coolant going into the air con by blocking any of the hoses that feeds coolant to the air con system (I haven't really looked into it, as I'm waiting for Tomorrow morning.) Or maybe someone here has a better quick fix while I'm able to get it to the mechanic. Any feedback is appreciated.
FYI, I won't be needing hot air anytime soon as I live in the tropic.
30 Jul 2023 02:03 #250037
by jcvs17cr
Replied by jcvs17cr on topic Coolant vapor though air con exits
Also, I don't think coolant is leaking inside the engine bay, as when I opened it there was no vapor, smell or any leak that I could see. That was I think the issue is somewhere in the air con system
- Thank you received: 2001
30 Jul 2023 04:04 #250039
Replied by Lambert on topic Coolant vapor though air con exits
If you are sure that the engine side is good it's easy enough to loop the heater hose together you will just need a suitable diameter bit of rigid pipe to give you something to sleeve the hoses and clamp them so they don't leak.
The following user(s) said Thank You: jcvs17cr
30 Jul 2023 05:36 #250040
Replied by mlines on topic Coolant vapor though air con exits
Are you sure you are leaking at all?
At certain combinations of humidity, air pressure and temperature your airconditioning will achieve "dew point" which means the water vapour in the air will condense and create a vapour cloud. You then get a cloud from the vents. My Range Rover does do this and I have also seen it on passenger aircraft.
Doesnt explain the smell but that could just be bacteria on the evaporator plate.
30 Jul 2023 14:06 - 30 Jul 2023 14:35 #250045
by jcvs17cr
Last edit: 30 Jul 2023 14:35 by jcvs17cr. Reason: How to remove hoses
30 Jul 2023 14:08 #250046
by jcvs17cr
Im sure it wasn't normal as the amount of vapor is a lot, almost like being in a sauna. And I did 2 small trips (with air con off) and both times the vapor started coming out when reaching normal temp
