Is my king pin gone?
09 Jun 2023 11:03 - 09 Jun 2023 11:07 #249481
by Scimike
Replied by Scimike on topic Is my king pin gone?
^^^^ What facade said.
The belts (power steering and Auxiliaries - 2 off) are as cheap as chips, circa £15 each or less). Going "by the book" they are inspect at 27k ( or 36month) and replace at 54k ( or 72 months). Inspect means look for damage or cracking, adjust tension if ok or replace.
It's no longer than 1hr to change both and requires no special tools, so it shouldn't be an expensive bill.
I'll also add you don't need to take the radiator out to change them, just in case this is the excuse. Plenty of room if you slacken the top radiator mounting bolts and just rock it back slightly. Ok plenty of room is exaggerating, enough room and I've got spades for hands.
If you keep getting what you consider are high prices try a recommended independent garage for a second opinion.
Last edit: 09 Jun 2023 11:07 by Scimike.
09 Jun 2023 18:46 #249484
by fordem
Replied by fordem on topic Is my king pin gone?
Time to create page: 0.468 seconds
