Is my king pin gone?
08 Jun 2023 18:26 - 08 Jun 2023 18:27 #249463 by Sophie B
Hi Guys,
After looking on the forum, it looks like my king pin is worn. Would you agree from the picture? If it is, how much do these things cost to have repaired?
S x
Attachment not found
Last edit: 08 Jun 2023 18:27 by Sophie B. Reason: Adding picture
08 Jun 2023 21:25 #249464 by DrRobin
Replied by DrRobin on topic Is my king pin gone?
Hi,
You will know if the king pin bearings have gone if you get a wobble in the steering wheel at around 50-55mph. It is usually the king pin bearings, not the king pin itself.
If you have got oil on the knuckle that is a sign the drive shaft seal is worn, it wears faster when the king pin bearings fail. It is easy to change once you get the hub off.
Finally the big rubber seal you can see in your photo is really just a dust seal, it just stops dust getting in to the grease round the knuckle.
King pin bearings, the drive shaft oil seal and the knuckle seal are about £50 a side from the BigJimny store, plus whatever your mechanic charges to fit them, which should be about 2 hours labour. It’s a fairly easy job if you can do it yourself.
Hope that helps
Robin
09 Jun 2023 04:15 #249471 by Sophie B
Replied by Sophie B on topic Is my king pin gone?
Hi Robin,
The car has only done 30k and I don’t feel any wobble. So that would point to the seal being gone that you mentioned?
Thanks a lot for your response, it’s most helpful.
S x
09 Jun 2023 06:55 #249472 by Scimike
Replied by Scimike on topic Is my king pin gone?
Yes your drive shaft oil seal has failed, hence the oil you can see.
When you change this seal you may as well change the Kingpin bearings, these are normally why the oil seal fails,  the play they introduce causes the drive shaft seal to wear. You can sometimes feel the play if you jack the car up and hold the wheel at 12 / 6 o'Clock and push /pull, or steering wobble at 50-55, but not always.
The large outer dirt seal may as well get replaced, as this keeps the dirt out of the kingpin bearing and stops them failing, which keeps the oil seal happy.
£50 for all these parts and max 2 hours to change. Easy DIY job if you feel like a go.
Simply repeating what Robin said, but giving the reasons why you end up changing 2 seals and 2 bearing when you see oil
09 Jun 2023 09:17 - 09 Jun 2023 09:17 #249476 by Sophie B
Hi Mike,
Thanks that all makes sense. Not being the mechanic type, I'm going to have to take it to a garage as it's due a service as well (34K one). My local Suzuki garage tried to tell me that it needs its belts changing (power steering and something else) and were quoting me £790!! Can that be right that it needs bets changing at 34K?
I went for a lesser service at £379 and mentioned the seal as well.
I'll wait to see what you guys say about the belts before calling people dishonest etc :)
S x
Last edit: 09 Jun 2023 09:17 by Sophie B. Reason: Spelt something wrong
09 Jun 2023 09:40 - 09 Jun 2023 09:40 #249477 by facade
Replied by facade on topic Is my king pin gone?
The aux belt and power steering belt last anything from 30,000 to 100,000 miles.  The garage probably want to change them based on age or deteriorating condition.
If the aux belt breaks it will strand you in the middle of nowhere, or if you merrily drive on with it broken (as people often do because it still runs and they are in the middle of nowhere, just the ignition light comes on) the engine will overheat within a couple of miles and be hugely expensive to repair, so it is worth changing the belts if there is any sign of cracking or deterioration on the inside- but it shouldn't cost hundreds of pounds at a garage.
Last edit: 09 Jun 2023 09:40 by facade.
Time to create page: 0.247 seconds
