Gen 3 - Engine Stalling at low revs - Service Bulletin
3 years 9 months ago - 3 years 9 months ago #247560
Gen 3 - Engine Stalling at low revs - Service Bulletin was created by mlines
Looking through the Suzuki Jimny bulletins, I found this one from March 2019 for Gen3 Jimnys (so the bulletin was released after the Gen3 was discontinued). I believe it applys to all Jimnys from 2008 but it may evne extend to 2005 (introduction of the VVT)
"Engine stalling may occur when pulling away from standstill using minimal accelerator pedal input."
This applies to both Manual and Automatic vehicles. If you think your Jimny stalls too easily then there is a software update for ECU,
This aoplies to ECU:
33920-76JB*
33920-76JC*
33921-76JA*
33921-76JB*
33921-76JL*
33921-76JM*
33922-76J7*
33922-76J8*
33922-76JG*
33922-76JH*
As ALL gen3 are out of warranty this upgrade would cost you, It is timed as a 40 minute activity on the Bulletin.#
33920-76JB*
33920-76JC*
33921-76JA*
33921-76JB*
33921-76JL*
33921-76JM*
33922-76J7*
33922-76J8*
33922-76JG*
33922-76JH*
Last edit: 3 years 9 months ago by mlines.
The following user(s) said Thank You: Lambert, Darthblaker7474
3 years 9 months ago #247629
by RainerK
Replied by RainerK on topic Gen 3 - Engine Stalling at low revs - Service Bulletin
Thank you very much for this information.
Could you also give the number of the service bulletin?
Thank you!
Thank you!
3 years 9 months ago #247630
Replied by mlines on topic Gen 3 - Engine Stalling at low revs - Service Bulletin
Q-SN-012
The following user(s) said Thank You: RainerK
- Darthblaker7474
- Elite Member
- Thank you received: 37
1 year 10 months ago #258947
by Darthblaker7474
Replied by Darthblaker7474 on topic Gen 3 - Engine Stalling at low revs - Service Bulletin
Is this something a local garage could do, or does it have to be a Suzuki dealer?
Mine occasionally runs rough after start on idle, when going it runs fine.
- Thank you received: 2005
1 year 10 months ago #258953
Replied by Lambert on topic Gen 3 - Engine Stalling at low revs - Service Bulletin
Dealer only I believe.
The following user(s) said Thank You: Darthblaker7474
1 year 10 months ago #258955
Replied by yakuza on topic Gen 3 - Engine Stalling at low revs - Service Bulletin
Does it say anything about it like "when cold or at a low temperature"?
My 05 VVT has started to allmost stop when cold, seems the idle up is not giving enough up when the weather is cold. 4-5 seconds after starting, the idle just drops for a few seconds before coming up again. Just about when you start to drive in some cases.
Only happens in cold weather.
Time to create page: 0.107 seconds
