Gen 3 - Engine Stalling at low revs - Service Bulletin
03 Jan 2025 07:01 #258956 by Lambert
Is your idle control valve good and clean?
05 Jan 2025 18:37 #258995 by CB1289
I also have noticed this problem - however mine is an earlier 2001 non-VVT. I wonder if the fix will be applicable/available to that model too?
06 Jan 2025 06:07 - 06 Jan 2025 06:08 #259003 by yakuza
I have no idea. :)
Havent seen it since the Liana engine came in. Also been wanting to check the PCV valve and the often clogged pipe going to the rear of the engine and the EGR something.
But these cold weather problems they are forgotten when spring comes and now the cold weather prevents me from finding motivation to go out. Luckily the frozen vaccum valve problems from last winter are gone.
Last edit: 06 Jan 2025 06:08 by yakuza.
Time to create page: 0.356 seconds
