Vacumm Hubs Just For a Change
- Thank you received: 648
23 Dec 2022 16:17 #246505
Replied by DrRobin on topic Vacumm Hubs Just For a Change
Thanks guys.
It’s automotive vacuum pipe I have been looking at, so guess it is suitable.
23 Dec 2022 20:35 #246511
by Scimike
Replied by Scimike on topic Vacumm Hubs Just For a Change
I like the colour coding idea.
If (when) the tubing fails on mine I was considering making a new set out of copper Brake pipe, simply as I have meters of the stuff and can flange the end to suit any flexible pipe connections. I was going to use the originals as a template, solder fixings in the same place etc, so it looks original without the cost.
Daft idea or good idea, open to all comments, just mulling the options?
Reading all I can on the subject it certainly looks like a pipe problem on yours.
Good luck with the fix when you do it.
23 Dec 2022 22:23 #246512
Great idea Mike, if you have the tubing, the skill and the time, why not make your own? After all it ticks all of the boxes, it will work, it’s recycling/up cycling, it will be satisfying to do and best of all it won’t cost anything, it will look great if you polish it before fitting, there is no downside.
In fact can you make me one please?
Have a nice Xmas everyone,
Robin.
Robin.
24 Dec 2022 09:35 #246516
by Scimike
Ok sounds promising.
Happy to make you a set if I can get it to work. I was going to make a template board from the originals so I can bend to shape off the vehicle, sort of how they do wiring looms.
It's something I'll have a go at If mine fail as time is not an issue for me. I need to remove my pipes intact, but at the moment they work so don't want to touch a runner.
Not sure about polished finish, may cost extra
Yes have a great break everyone
24 Dec 2022 10:06 #246521
by Busta
Replied by Busta on topic Vacumm Hubs Just For a Change
Thank's for reminding us the vacuum hubs use a vacuum Roger.
After fighting with them when removing the front diff a couple of times I was quite happy to get rid of the pipes along the axle. The standard routing doesn't seem to be very well thought out. I certainly wouldn't put much effort into replicating it.
- Roger Fairclough
- Thank you received: 220
27 Dec 2022 15:09 #246572
by Roger Fairclough
Roger
Replied by Roger Fairclough on topic Vacumm Hubs Just For a Change
It wasn't the hubs I was worried about Busta. My comment was made in the spirit of being helpful, and didn't warrant your comment. I have known that thin walled hose can collapse when subjected to a vacuum. If I have offended anyone with my caveat, I apologise.Thank's for reminding us the vacuum hubs use a vacuum Roger.
Roger
Time to create page: 0.188 seconds
