Vacumm Hubs Just For a Change
- auchenblae
- Elite Member
- Thank you received: 25
12 Dec 2022 20:01 #246333
by auchenblae
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Vacumm Hubs Just For a Change was created by auchenblae
2016 car
At 24,000 miles approx it needed new king pin bearings otherwise no issues now 30,000 miles.
On Thursday evening coming up our track it was a bit muddy with snow on the ground and the back end was moving about, went into 4WD and the back end behaved its self.
On Friday afternoon visited a friend and the car was parked down a snowey hill. I reversed it up the hill and the back wheels were spinning and 4WD made no difference, the back wheels were still spinning.
We towed it up the hill. Best guess it was not going into 4WD but the green 4WD light was on and not flashing!!!!!!!!!!!!
Put the car on the two post lift today and lifted it just off the ground.
Started the car put it in gear and the back wheels are going round.
Click into 4WD and the offside front wheel spins slowly and nothing from the nearside front wheel!!!!!!!!!!!!!! You could stop the offside wheel with no issue.
I decided it was the nearside freewheeling hubs faulty!
Removed both vacuum hubs and changed from side to side, both looked good and the same issue no drive to the nearside.
Removed nearside wheel and caliper to get into the two metal vacuum pipes on the back of the hub. The top one was clean, the lower metal tube was full of clean grease. Used a wire to remove the grease.
Put everything back together and have 4WD now.
At the MOT in early November, I got an advisory that the front nearside brake was slightly binding, but taking temperature readings after a no braking run shows say offside front disc brakes 16C and nearside front discs say 20C.
Not an issue thinks I!
We know an overheating disc brake causes the bearing to loose grease and that stops the vacuum from lasting in the hubs. From our 2007 to 2016 Jimny.
I wonder if the grease at the lower metal vacuum tube is the start of a failing nearside wheel bearing from the slight brake binding reported on the MOT. No issue at all when you spin the bearing.
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
- auchenblae
- Elite Member
12 Dec 2022 20:04 #246334
by auchenblae
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Replied by auchenblae on topic Vacumm Hubs Just For a Change
Just wondering if I used too much grease when I did the kingpin bearings?
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
12 Dec 2022 22:09 #246337
by Busta
Replied by Busta on topic Vacumm Hubs Just For a Change
It's very common for people to use too much grease when doing the kingpins! If you put excess grease on the stubby CV shaft then that would be very likely to end up in the vacuum hose that locks the hubs, as the "lock" vacuum path is through the inside of the spindle where the shaft goes. Grease from a wheel bearing failing would sooner find its way into the unlock hose.
However, it is my understanding that the unlock hose is the lower one, on the front of the hub, which sounds like the one you had to clean? Obviously it's a 2 way system so if either pipe is blocked it will have an affect on the operation of the hubs, but that does mean the wheel bearing is more likely to be the source of the grease. Have you ever removed the wheel bearing?
- auchenblae
- Elite Member
12 Dec 2022 22:35 #246339
by auchenblae
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
I replaced both wheel bearings on our 2007 to 2016 Jimny. I have never replaced the wheel bearing on this car I do have the fancy wheel bearing bolt spanner and a 12 tonne press so not an issue if it needs changed.
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
- auchenblae
- Elite Member
12 Dec 2022 23:11 #246340
by auchenblae
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
I used the black waterproof grease that Martin recommends for the king pin job. The grease today was a clean straw colour so that is tending towards wheel bearing grease.
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
13 Dec 2022 05:26 - 13 Dec 2022 05:30 #246342
Replied by yakuza on topic Vacumm Hubs Just For a Change
Mine has failed to engage 4x4 for the first time yesterday. Right side is waiting for new bearings has a leaky inner seal so the grease is full of oil. Left side is newly done. Too cold now with minus 15 to do the right side but I suspect the icy conditions has made any water ingress freeze.
Had the same problems with the maunal hubs in sub zero conditions with old grease, could not turn them. but those days I used to flip the over to locked at the beginning of winter and they stayed there until spring.
At first they engaged after a while of a period of alot of blinking and not so much 4x4 engiging or disengaging until they finally made it.
Now I get a blink of 4x4 light after about 3-4 seconds af holding the 4x4 button and then nothing.
Still I think a service to the system will fix this. re grease of the hubs and full service of the bearings and seals. I like the vacuum system when it works and with my experience of frozen manual hubs they would not help me so i cling to my original ones still
They worked down to minus 8.
Last edit: 13 Dec 2022 05:30 by yakuza.
Time to create page: 0.207 seconds
