4WD working but light flashing
30 May 2022 20:48 #243529 by Busta
You can check them by sucking on a hose attached to the ports on the hub. You should feel resistance. If air flows freely then there is a leak. Infact the same test can be done on any part of the system.
  • spookyandroid
31 May 2022 05:35 #243534 by spookyandroid
Replied by spookyandroid on topic 4WD working but light flashing
Thanks Busta. Will do more research on this. Do you know of any guide/video on replacing these seals?
31 May 2022 06:44 #243535 by Busta
A wheel bearing change video will show how to get to the seal behind. To do the CV one you can either remove the king pins like you did befor and get to it that way or go this route which is much quicker if everything comes undone:
The following user(s) said Thank You: spookyandroid
Time to create page: 0.143 seconds
