4WD working but light flashing
  • spookyandroid
30 May 2022 17:54 #243520 by spookyandroid
4WD working but light flashing was created by spookyandroid
So, I wanted to restore the 4WD functionality back from manual hubs to vacuum lockers.
Replaced the solenoid/switch
All pipeworkHubs1 kingpin bearings/seal, other side was done 12 month ago.
I jacked the car and tested both sides, the wheels are locking when 4WD engaged, however the 4WD light continually flashes as though I have a vacuum leak.
What could it be, to my understanding there isn't anything left, with perhaps the exception of the pipe to the cylinder under the wing?
Tia
Danny
30 May 2022 18:53 #243522 by Lambert
Have you checked the condition of the wiring at the transfer case end and also the 4x4 control module?
30 May 2022 19:01 #243523 by Busta
There are 2 seals in the hub that the vacuum system relies on. One is where the CV joint goes through the back of the hub spindle; this one affects the hub un-locking. The other is behind the wheel bearing and affects the hub locking. They can develop a slight leak that is enough stop the vacuum switch registering, but not enough to stop the hubs working.
  • spookyandroid
30 May 2022 19:19 #243525 by spookyandroid
Replied by spookyandroid on topic 4WD working but light flashing
All wiring looks good, control box all good too.
  • spookyandroid
30 May 2022 19:21 #243526 by spookyandroid
Interesting to know. I'm not overly technical but I can do things if I'm replicating a video or someone. I changed the kingpin bearings and both seals ( one at the back and the one inside) I take it these are the two you're referring to or is there another somewhere else?
30 May 2022 20:45 #243528 by Busta
The seals you replaced when doing the kingpins are not part of the vacuum system. The seals I'm talking about are in the hub. You need to remove the wheel bearing to acces one, and the whole hub to access the other.
