No Power to my ODB socket
20 Nov 2021 19:47 #240251 by GWFBrown
Hi everyone.
I have a yellow engine warning - when I check with my Maxscaner there appears to be no power at the OBD socket  - can any one help'
Regards.
Gordon.
20 Nov 2021 20:06 #240252 by fordem
Replied by fordem on topic No Power to my BDB socket
Maybe a blown fuse?
Maybe a broken wire or bad connection?
Maybe tell us what it is you're driving so we can figure out which fuse it might be, or even if it's OBD2 compliant?
Has the "Maxscaner" ever worked on this vehicle before?
What's your experience with auto-electrics like?
20 Nov 2021 22:02 #240254 by DrRobin
Replied by DrRobin on topic No Power to my BDB socket
I have a Gen 3 and an code reader, that works perfectly, but when I plug my Bluetooth dongle in, it’s a bit iffy. When I looked at the BT dongle it has rectangular pins which are 90 degrees different to the Autel, so I simply used a pair of pliers to turn the pins through 90 degrees and hey presto, no more iffy connection problems.
21 Nov 2021 07:09 #240259 by GWFBrown
Replied by GWFBrown on topic No Power to my ODB socket
Hi
My Jimny is a 2011 SZ3.
I've never used it on this Jimny before, but works fine on my Landrover !!
Thanks
Gordon
21 Nov 2021 07:13 #240260 by GWFBrown
By the way my scaner is a MaxScan GS500
Gordon.
21 Nov 2021 09:21 #240262 by Lambert
Replied by Lambert on topic No Power to my ODB socket
Some scanning tools can be a bit picky about Japanese cars. Your scanner is not a jlr specific one is it?
Time to create page: 0.098 seconds
