No Power to my ODB socket
21 Nov 2021 13:08 #240265
by fordem
Replied by fordem on topic No Power to my ODB socket
The "dome light" fuse (#14) is the one that powers the DLC (Data Link Connector) aka OBD connector, along with other things, so if your dome light is working, and there's no power at the DLC connector, you have some sort of a wiring fault.
This takes us back to my earlier, as yet unanswered question - what's your experience with auto-electrics like?
Get a voltmeter and check for 12V on pin 16 of the connector, use a chassis/body ground as the reference for the initial test, if the 12V is present, use pin 4 & then 5 as the reference - 4 & 5 are the grounds in the DLC connector so an open circuit there can cause the scan tool not to power up.
21 Nov 2021 16:30 #240270
by GWFBrown
Replied by GWFBrown on topic No Power to my ODB socket
Hi fordam.
Problem solved, thank you so much.
The tie up between the dome light and DLC Connecter solved the problem.
The engine warning light was not a problem, only that the DLC was not powered
For interest only : my Dome Light fuse was No. 8 not 14.
Thank you again.
Gordon
Thank you again.
Gordon
Time to create page: 0.159 seconds
