Re:Re:50mm lift - sway / role bar adjustment spacer ?
17 Sep 2021 13:46 #238722 by lookonimages
X8GGY wrote: No, they're apparently different spacing between the bolt holes...
Hence my one single negative feedback :(
(The delivery time comment was unfair as they were shipped via eBay's Global Shipping Program!!!)
I'll have to order a bush metal loop strap (from Martin) to research and produce them for the Gen4...
Cheers,
Dave
Thanks Dave.
Appreciate you doing this for jimny owners.
Dont read to much into that one negative comment.
Keep doing what you do. !!
  • Dirtbird
17 Sep 2021 15:05 #238724 by Dirtbird
Cheers,
Dave
Thanks Dave.
Can I just Chime in on this? I bought this kit from Dave and its first class. I've also found Dave to be super supportive and helpful when it comes to trying to source bits and bobs locally . Cheers Dave
18 Sep 2021 04:51 #238739 by Lambert
That's because Dave is an absolute legend!
The following user(s) said Thank You: lookonimages
  • X8GGY
19 Sep 2021 11:59 #238787 by X8GGY
Oooh, Thanks Guys
  • Sean65
20 Sep 2021 12:52 #238820 by Sean65
Can i just confirm having read this thread with interest and having just fit a 50mm lift that the total removal of the ARB is accepted practice.  Cheers
20 Sep 2021 18:17 #238832 by lookonimages
Sean65 wrote: Can i just confirm having read this thread with interest and having just fit a 50mm lift that the total removal of the ARB is accepted practice.  Cheers
From my perspective it all "depends" onwhat you mean with 50mm lift.
Spacer lift ?
Spring lift ?
Proper stronger shocks ?
It is not accepted pactice but some do it, but they know the impact of such a removal.
Time to create page: 0.227 seconds
