Re:Re:50mm lift - sway / role bar adjustment spacer ?
- lookonimages
- Thank you received: 72
12 Sep 2021 12:20 #238515
by lookonimages
50mm lift - sway / role bar adjustment spacer ? was created by lookonimages
General question. If you have added a 50mm lift, should you not also ad spacers to where swaybar connect to chassis.
Your opinions.
Your opinions.
12 Sep 2021 12:52 #238517
by Keithy
Replied by Keithy on topic 50mm lift - sway / role bar adjustment spacer ?
Yes....although it will also need an offset rearward to allow for the different arc the axle now describes.....I removed mine.....no difference on-road other than single wheel hits on speedbumps are a little milder.
The following user(s) said Thank You: lookonimages
13 Sep 2021 09:54 - 13 Sep 2021 11:13 #238549
by Busta
Replied by Busta on topic 50mm lift - sway / role bar adjustment spacer ?
Best to remove it completely, but it will still operate normally in the standard position.
Adjustable drop links are available but there is only so much shorter you can go.
Last edit: 13 Sep 2021 11:13 by Busta.
- X8GGY
17 Sep 2021 11:47 #238712
Replied by X8GGY on topic 50mm lift - sway / role bar adjustment spacer ?
I've just launched a range of these -
There's 6mm, 12mm, 25mm available now, and 38mm going into production as soon as the bar stock arrives...
Link to eBay
Dave
ZookBOB
Link to eBay
Dave
ZookBOB
- lookonimages
17 Sep 2021 11:58 #238714
by lookonimages
Replied by lookonimages on topic Re:50mm lift - sway / role bar adjustment spacer ?
Thanks zook. Do these also fit the gen4.
- X8GGY
17 Sep 2021 12:05 #238715
Replied by X8GGY on topic Re:50mm lift - sway / role bar adjustment spacer ?
No, they're apparently different spacing between the bolt holes...
Hence my one single negative feedback
(The delivery time comment was unfair as they were shipped via eBay's Global Shipping Program!!!)
I'll have to order a bush metal loop strap (from Martin) to research and produce them for the Gen4...
Cheers,
Dave
Cheers,
Dave
Time to create page: 0.346 seconds
