Hub locking by itself??
- Elaine
09 Jun 2021 05:34 #235678
by Elaine
Replied by Elaine on topic Hub locking by itself??
Well, over a month later and it's suddenly started doing it again!
The only way to stop the horrendous noise, is to momentarily put it into 4WD. The noise stops immediately so I put it straight back into RWD and carry on with my journey. It's sometimes doing it 4 or 5 times within a mile now.
On the way home from work this morning I noticed a click sound a few moments before the horrendous noise appears (the horrendous noise sounds similar to when you put a stick in the spokes of a turning bicycle wheel, but much louder & more aggressive). Could it be that the click is a hub (or two) trying to lock? And the front driveshafts attempting to engage is the cause of the horrible noise?
My hubby is going to lock the hubs, to see if that stops the horrible noise. If it doesn't, what else might it be please?
09 Jun 2021 08:35 #235683
by Busta
Replied by Busta on topic Hub locking by itself??
As I said above, it's probably a leaky vacuum solenoid.
- Elaine
09 Jun 2021 19:15 #235688
by Elaine
Yeah, sorry I forgot to add that Reg was also going to check for a leaky vacuum solenoid... And it seems that may well be the (or part of the) issue. Are new replacements still available?
09 Jun 2021 22:35 #235691
by Busta
Yes new are available from Suzuki and used are available from anyone who has fitted manual hubs. Lambert on here will have a couple spare on his new purchase.
An easy way to rule out a leaky solenoid is to pull the hose that feeds the vacuum system off the inlet manifold and blank it of with some tape.
- Thank you received: 2004
10 Jun 2021 04:54 #235694
Replied by Lambert on topic Hub locking by itself??
Not that I have done but it is possible to dismantle and rebuild the vacuum solenoids which is the cheapest option. Otherwise new replacement parts are in the same price range as manual hubs.
Time to create page: 0.085 seconds
