Hub locking by itself??
  • Elaine
01 May 2021 13:56 - 01 May 2021 13:59 #234794 by Elaine
Hub locking by itself?? was created by Elaine
My 2001 Jimny (lever operated transfer box) started doing a strange thing today... a horrible noise which sounded like a fast rachet/something stuck in brake disc/spline not engaging fully, noise coming from the front offside wheel area.
It's done it twice today, once at around 25mph, then again about 20 miles later when I was doing 40mph on a busy dual carriageway (new pants nearly needed!). Needless to say, I whacked my hazard lights on, slowed down & pulled over pretty damn quickly!
When pulling off again the noise had gone, but the car felt different - almost like it had gone into 4wd. I turned off the dual carriageway into a side street which was only a short distance up the road and drove up & down it doing a u-turn in junction. Just after the u-turn I heard a clunk noise which sounded like the hub locking/unlocking... is this even possible without me moving the lever?
This Jimny has been my main daily drive for 14 years, so it's definitely a new issue.
Any suggestions welcome.
Thanks in advance,
Elaine.
Last edit: 01 May 2021 13:59 by Elaine.
01 May 2021 14:53 #234795 by jackonlyjack
Sounds to me like the magnet in the vac hub is not holding it in off position
You can remove the vac hubs and take it for a drive
01 May 2021 16:39 #234796 by Busta
Replied by Busta on topic Hub locking by itself??
I've not had the problem myself but I believe it can be caused by a leaky vacuum solenoid. They are found just below the battery. Anyone that has fitted manual hubs will likely have 2 working spares they could sell you.
01 May 2021 17:42 #234797 by Lambert
Replied by Lambert on topic Hub locking by itself??
Are you experiencing any limitations in turning one way or the other? If so it may not be hub related.
  • Elaine
05 May 2021 13:40 #234873 by Elaine
Replied by Elaine on topic Hub locking by itself??
Thanks for all of your replies.
We checked the vacuum filter and all of the connections. The filter had disintegrated, there's now a bit of ITG filter in it's place.
The vacuum pipes were corroded, so we've cleaned those up and will be replacing them with copper pipes soon.
The horrendous noise which had happened a couple of times only 20 odd miles apart, might have been a coincidence and totally unrelated...
...the brake shield on the driver's side was badly rusted and we think a large flake of it might have caught the disc.
The noise hasn't occurred since and it's no longer wanting to go into 4x4 itself.
Hopefully, I'll get many more years out of my metallic green on/off-road machine.
Many thanks, again.
05 May 2021 13:43 #234874 by Lambert
Glad we were of assistance.
Time to create page: 0.173 seconds
