2014 Gen 3 Interior light
04 Feb 2021 20:33 #232488
by Tikka 260
Replied by Tikka 260 on topic 2014 Gen 3 Interior light
Thanks, appreciate the input.
- Thank you received: 679
05 Feb 2021 14:10 #232501
Replied by DrRobin on topic 2014 Gen 3 Interior light
The door switches come out of the frame after removing one screw. If it is not a switch perhaps a wire has chafed and is shorting to the metal. If you take the switches out and the light goes off you have found the problem switch, but if it is a wire it might be harder.
There is no control box, just plain wiring.
There was someone on here before Xmas who had mouse in the car, chewed through the seatbelt and some cables, could that be the problem?
05 Feb 2021 14:16 #232502
Just had another thought, my interior lights come on when I unlock the car, at least for a few seconds and then go out, so there must be some sort of relay/timer connected to the interior light from the unlock mechanism, perhaps that has failed.
Do the lights go out when you lock the car with all doors closed? If they do it might well be the lock/unlock box. If they stay on when you lock the car it still looks like a switch or wire.
Does the light go out, if you move the switch on the light to off? I think mine is three position, Off, door activated or on, if it stays on regardless, I then suspect the light fitting or switch in the light.
The following user(s) said Thank You: Tikka 260
05 Feb 2021 16:48 #232503
by Tikka 260
Many Thanks for your advice, it gives me some avenues to check out. Incidentally the key fob operated central locking ceased to work late yesterday.
The interior light will switch off using the built in 3 position switch in the OFF position, but remains ON when placed in the central position, door operated, So, it appears to be either the door switch(s) and or the door locking component that is causing the fault, or an earth short somewhere in the wiring.
02 Mar 2021 10:03 #233389
by Tikka 260
Thank You All for offering your advice, thankfully the fault has been traced to the spade connector on the rear door switch which had corroded through and sheared off, making a short to earth from the tattered remains of the spade connector.
The offending wire has been isolated and everything is now back to normal, and the central locking system is also operating as it should. A replacement door switch is on order and will be fitted in the fullness of time.
If anyone wants or needs a Central locking control module, I have one available from a "breaker", it works fine.
Thanks again
ATB
Peter
Thanks again
ATB
Peter
