2014 Gen 3 Interior light
04 Feb 2021 15:07 #232471
by Tikka 260
2014 Gen 3 Interior light was created by Tikka 260
Hi Everyone,
A new problem for me, without any prior symptoms the interior light remains ON, I've checked the door and tailgate switches and they appear to be functioning as they should, I've also checked and cleaned the inside of the switch housing on the mirror mounting. Problem remains. Is there a control module somewhere that may be causing the problem? I am no electrical wizard at all, but I know a man who can understand auto electrics if we just had some idea of what we are looking for?
Any suggestions will be most welcome, and thanks in advance.
ATB
Peter
ATB
Peter
- Thank you received: 2004
04 Feb 2021 18:22 #232478
Replied by Lambert on topic 2014 Gen 3 Interior light
Have you opened up the door switches beyond just pushing the outer rubber bits?
04 Feb 2021 19:43 #232482
by Fossie
Replied by Fossie on topic 2014 Gen 3 Interior light
Had the same problem with one of our Jimnys and the opposite as in wouldn't come on!
Try a few layers of tape where the switch plunger meets the door jam when closed , if after a few layers it goes out , th switch hadps gone past its housing , either replace switch or leave tape .
04 Feb 2021 19:51 #232483
by Tikka 260
Replied by Tikka 260 on topic 2014 Gen 3 Interior light
Thanks for the input, I'll give that a GO tomorrow IF it stops raining out there
04 Feb 2021 20:01 #232484
by Tikka 260
No, I'm reluctant to start pulling stuff to bits just to eyeball it. If there is something specific to look for then I'll go ahead, but with my electrical expertise I''m no better than a sightless person.
04 Feb 2021 20:05 #232485
by RainerK
Replied by RainerK on topic 2014 Gen 3 Interior light
The door switches connect a wire to the frame. When the door is closed, the the wire is disconnected. I would disassemble the switch in the drivers door first an check if, when closed the wire is disconnected.
