Re:Tyre Pressure on Gen4 w BFG K02 - still a bit confused
- Groenewald
11 Jan 2021 10:15 #231689
by Groenewald
Replied by Groenewald on topic Tyre Pressure on Gen4 w BFG K02 - still a bit confused
I have been pretty quiet on this one and testing a range of pressures.
I have finally settled on this one: 28psi / 1.93 to 2 bar. (For general road use)
- Thank you received: 1998
11 Jan 2021 10:57 #231691
Replied by Lambert on topic Tyre Pressure on Gen4 w BFG K02 - still a bit confused
You are going to find that you will wear the centre of your tread at an accelerated rate at that pressure. As we have all said start at the standard 26psi and go lower.
11 Jan 2021 13:29 #231694
by saxj
Replied by saxj on topic Tyre Pressure on Gen4 w BFG K02 - still a bit confused
2 bar is way too high. 1.8 bar is the manufacturer's recommendation. The bigger the tyre, the lower the pressure. I wouldn't go higher than 1.7 bar on 215/75R15. I run 1.4 bar on my 235/75R15's.
- lookonimages
- Thank you received: 72
11 Jan 2021 16:17 #231700
by lookonimages
Replied by lookonimages on topic Re:Tyre Pressure on Gen4 w BFG K02 - still a bit confused
As said many times. 1.6 to 1.7 bar.
12 Jan 2021 12:12 #231729
by 300bhpton
If its a Gen 4 you can't go lower as the dash lights up like a Christmas tree and stops it telling you anything else.
Unless there is a way to adjust the TPMS settings or disable them.
Replied by 300bhpton on topic Tyre Pressure on Gen4 w BFG K02 - still a bit confused
Lambert wrote: You are going to find that you will wear the centre of your tread at an accelerated rate at that pressure. As we have all said start at the standard 26psi and go lower.
12 Jan 2021 15:05 #231739
I was under the impression that the emulator modules were for doing that, delete the wheel sensors and set the emulator then regularly check the tyre pressure manually like a normal person?
Time to create page: 0.244 seconds
