Engine Squeal
- Kizzy--wizzy
6 years 1 week ago #229813
by Kizzy--wizzy
Replied by Kizzy--wizzy on topic Engine Squeal
My understanding is there were no obvious signs of damage on the pulley, yes it was brand new, as was the alternator which we changed as we thought it may have been this previously and as it was being worked on we did it at the same time.
Yes my husband is very competent, he had worked on cars for years, he is at the point of pulling his hair out as he cannot see what else would be causing the problem and now the battery light is on constantly (it is dimmer than the other lights on the dash).
Totally understand your questions, as I'm sure you can tell, I'm not mechanically minded but assure you my husband is, we checked in the Suzuki website for tensions and followed this
Thank you
Thank you
- Thank you received: 679
6 years 1 week ago #229814
Replied by DrRobin on topic Engine Squeal
Belt squeal could be something on one of the belts, like oil or water, but is nearly always that the belt is too slack.
The tension is 6-9mm movement either side in the middle of the longest length, on the bottom is the easiest place to measure. Or try twisting the belt with the fingers, it should twist through 90 degrees either side and no more.
I was surprised just how tight the belts need to be.
Alternator not charging is more of a problem, with the bonnet up and the engine running at idle is the alternator going round? If you have a multimeter is it generating any voltage? You might just have a faulty alternator, it does happen even with a new one.
Try the old alternator back on, it will only take an hour to swap over. Whilst it is off you could try running the car quickly and check for squeal this would tell you if it is the PAS or alternator belt.
6 years 1 week ago #229815
With the belts off did the alternator turn easily? What about the water pump, the PAS pump and the tensioner did they all run free and smooth?
Just out of interest what was the old crank pulley like, did the rubber in the middle show signs of wear?
Did you fit new belts, it might be one of your belts that is causing the squeal?
Unless the alternator is not turning I think you might have two problems, one a little bit of belt slip and the other a faulty alternator, electrical connection or if the Jimny has one a regulator.
6 years 1 week ago #229816
Replied by mlines on topic Re:Engine Squeal
DrRobin, quite often you cannot see problems when you take the pulley off. A better way of seeing a failing rubber separator on the pulley is to look at the pulley rotating using a bright light, you will see a distinct wobble. Perhaps even film it with one of the modern smartphone slo-mo functions.
Another way to track down the source of sound is to hold a long hollow cardboard to your ear and (carefully) move it around to locate the loudest sound
- Kizzy--wizzy
6 years 1 week ago #229821
by Kizzy--wizzy
Hi all, thanks again for your suggestions and replies,
My husband has tightened the belt even more and fingers crossed it seems to have stopped the squeak. But we are both expecting it again tomorrow morning!
The battery light is still on dimly but it is charging as he's checked with a multimeter, will double check the wiring at some point to the dashboard.
Thank you
Kind regards Christine
Thank you
- Roger Fairclough
- Thank you received: 225
6 years 1 week ago #229822
by Roger Fairclough
Replied by Roger Fairclough on topic Engine Squeal
Keep a can of WD40 - or similar - handy when you start the engine. If the squeal is present, spray directly onto the belt. If squeal disappears, belt or pulley is culprit. Do one belt at a time. Also check pulley alignment.
Where are you based? You may be near a forum member.
Roger
Roger
Time to create page: 0.098 seconds
