Engine Squeal
  • Kizzy--wizzy
24 Oct 2020 16:16 #229460 by Kizzy--wizzy
Engine Squeal was created by Kizzy--wizzy
Thank you for add, I hope someone can help, you might need a cup of tea though, it's a bit of a long one...
I bought a 58 plate Jimmy in July 2019, in February/March 2020 I started to get an intermittent squealing when starting it in the mornings, it got progressively worse so we changed the two auxiliary belts, this solved the problem for a couple of weeks but then it started again. We took the belts off & cleaned the pulley grooves & changed the tensioner, it persisted. We then went into lockdown & it got a run once a week to tick it over, it made no squealing.
I started driving it regularly again in August to & from work, the squealing like a banshee now happens every time you start the engine & continues until it is warm.
We changed PAS/AC belt again because it looked as though it was linked to steering as squealing was worse on full lock left & right, also changed the battery. This made a slight difference in the house but still persisted.
Today we have changed the PAS pump & fitted a belt that bypasses AC pump as we sprayed the AC pulley & clutch with dry lubricant & the noise almost stopped which led us to think the AC pump pulley was the issue.
It looked as though that had solved the problem but leaving engine off for half hour to change headlights it returned when starting the engine albeit not quite so aggressively.
Our next thing we plan to change is the alternator but does anyone have any suggestion of anywhere else we should be looking. The belts are tensioned correctly & it is not particularly easy to diagnose where the sound is coming from as it moves around the engine bay.
Whereas before it looked like the problem was linked to steering because it got worse when moving the steering, it is now happening when I turn the lights on or put in drive/reverse.
Thank you for reading this far & I appreciate any helpful advice before I pull my hair out & my husband leaves me!
24 Oct 2020 16:34 #229462 by Lambert
Replied by Lambert on topic Engine Squeal
Welcome to the forum. It's sounds like the main crankshaft drive pulley is failing. They're a bonded composite type and the bonding doesn't last forever. If the engine is running then it's sometimes possible to see the drive pulley wobble or running out of true. With the engine off and the belts removed there shouldn't be any detected play in the main pulley. Replacing should be straightforward assuming you can get the crankshaft bolt out, however it has a large integral flange and this corrodes making an already ft bolt a bit of a git to undue. It is best to remove the radiator to improve access and to have a heavy hitting impact wrench too.
The following user(s) said Thank You: Kizzy--wizzy
  • Kizzy--wizzy
24 Oct 2020 16:46 #229464 by Kizzy--wizzy
Replied by Kizzy--wizzy on topic Engine Squeal
Thank you, much appreciated.
My husband had wondered about that earlier but I think he had hoped it wasn't, another gent on FB also suggested this so looks like that is the next place to start, do you think change the alternator too?
24 Oct 2020 16:59 #229466 by Fossie
Replied by Fossie on topic Engine Squeal
One of my daughters Jimny did this, having changed the belts more than once, they snapped often aswell, the alternator was renewed and the squealing stopped. On inspection the alternator was fine until we looked in side at the windings and found a bearing was siezing .
The other daughters squealing ( jimny not her) was curtailed when I cleaned around the rear of the engine which was covered in oil ( which I still need to figure out) . I found the plate covering the flywheel was missing and hence the flywheel covered in oil so cleaned off aswell.
  • Kizzy--wizzy
24 Oct 2020 17:06 #229467 by Kizzy--wizzy
Thank you, we will check that too, I do have a new alternator so maybe should change it. Thanks
24 Oct 2020 22:09 #229474 by DrRobin
Replied by DrRobin on topic Engine Squeal
Squealing on start up is nearly always a belt, usually too slack. My crank pulley failed in the summer, fairly spectacular, it chucked both belts off, there is a thread on here about it.
Anyway, prior to it failing one of the belts squealed at start up, it was the Power Assisted belt, now that the pulley is replaced and new belts no more squealing.
You can tell which belt it is, try moving the steering when cold, especially near lock, if it is the PAS belt it will get worse. If it s the the AC belt then it will change if you put the AC on.
The only other thing that makes that noise is the clutch thrust bearing, but you know if it is the clutch, it changes when you push the clutch in.
I was surprised how short a life the crankpulley has, I have never known it to fail on any other vehicle I have owned, but on a Jimny they seem to go quite quickly (every 50k miles).
