Re:Jimny jb74 pulling to the left
  • wicho001
  • Visitor
  • Visitor
04 Aug 2020 15:32 #226078 by wicho001
Jimny jb74 pulling to the left was created by wicho001
Hello guys,
Im having my first "issue" with my jimny and would like to have your opinion on this matter.
I just notice that my jimny is pullint to the left, I dont remember if this happened after I fitted the 2" suspension lift or after fitting the castor correction bushes but the thing is that I need to compensate my steering wheel to the right in order to go straight, if I let go the steering wheel the car pull to the left. NOTE: The pull is very minimal.
Took the jimny to 2 differents shops (with brand new wheels aligmment machines) and everything seems ok. Same tire pressure on all 4 tires, wheels checked and rotation done, what else do I need to check?
Thanks in advanced,
Luis
Sent from my SM-G975F using Tapatalk
04 Aug 2020 16:04 #226079 by Roger Fairclough
I assume that you are driving on the same roads as before the suspension lift so we can discount road camber.
So, did you have the castor checked before the lift? I ask because there is quite a variation between acceptable limits with the standard suspension and adding correction bushes can take it beyond these limits. It's best to check before the lift to get some idea as to whether you need the bushes at all. When the lift was done were the bolts on the frame end of the suspension arms slackened off and then torqued up after the car was back on the ground? this is important as you do not want tension in the bushes when the car is static. Do you have copies of the information sheets from the alignment companies and they list the castor angles? I don't know what the limits are but someone on the forum will hopefully help here.
The other items to check are tyre pressures, toe in or out and binding brakes.
Roger
04 Aug 2020 16:11 - 04 Aug 2020 16:12 #226080 by Scimike
Hi - assume you are in the UK?
The natural camber on the road surface to drain water to the left can cause a vehicle to pull very slightly to the left. You need to find a flat carpark and see if it's still happening to eliminate this as a cause.
That only leaves the brake on the left side, if it's binding slightly or the wheel rotating is not as free as the right you can experience a pull, not necessarily only when you brake.
I am out of ideas now:)
Roger types faster than me. - what he said as well
Last edit: 04 Aug 2020 16:12 by Scimike.
  • wicho001
  • Visitor
  • Visitor
04 Aug 2020 16:17 #226082 by wicho001
Replied by wicho001 on topic Re:Jimny jb74 pulling to the left
Scimike wrote: Hi - assume you are in the UK?
Thanks for you reply.
Not in the UK mate. I will check the brakes then. Thanks again.
  • wicho001
  • Visitor
  • Visitor
04 Aug 2020 16:47 #226084 by wicho001
Not a brake issue, both front tires rotated giving the same amount of effort.
04 Aug 2020 16:55 #226085 by mlines
Have you adjusted the steering wheel to be central after the lift?
Time to create page: 0.150 seconds
