Aircon problem
18 Jul 2020 21:49 #225303 by Scimike
Replied by Scimike on topic Values in five years time
Hi Clutha, thanks, no Aircon expert though, can't quite get mine to work 100% at the moment due to my regas issue. I have a plan to gas it until the fan cuts in / out at the same ratio as a good one, then call it quits.
Yes the rpm will increase to about 900 - 1000 with the AC on to compensate for the load of the compressor, it's normal.
Mike
  • Clutha
19 Jul 2020 10:43 #225316 by Clutha
Replied by Clutha on topic Values in five years time
I’ve been studying owners manual (unusual for me!) and see that mixing gases is a no no. Also charging video showing pressure gauge connected between lp side and gas canister, sounds the safest way to me.
Recharging systems I worked on was a totally different procedure, but our lecturers made vehicle recharging sound simple.
Just studied some YouTube stuff and am now sure my ac compressor clutch is stuck on. Accounts for rubbish fuel consumption, & less than brilliant heater performance.
19 Jul 2020 12:48 #225321 by Keithy
Replied by Keithy on topic Aircon problem
R12 was quite a nasty gas.....134A not so much so....no idea how much oil was in the system but oil is hard to compress.....nigh on impossible in fact.
Replace the pipe and have it evacuated and refilled with the correct amount of oil and pressure of gas......then let me know what the amounts are for when I have my Jimny refilled.....in a year or so's time :D
The following user(s) said Thank You: Dunders
  • Clutha
19 Jul 2020 18:19 - 19 Jul 2020 18:21 #225334 by Clutha
Replied by Clutha on topic Aircon problem
The plot thickens.
Had a quick look at ac compressor clutch, it’s definitely not releasing. Strangely when I started the engine the condenser fan was running for a few seconds, when I had a look it was turning but appeared to have ‘switched’ off. Any operation of ac switch gave no change in engine revs and fan never came on again. Ventilation air was definitely being cooled. Checked fuse for compressor, ok. Fuse box cover markings indicated relay (middle of 3) was for ac. There was no relay fitted !!! Next check is to see if 12v is being supplied to compressor clutch, and get a wiring diagram!
Last edit: 19 Jul 2020 18:21 by Clutha.
19 Jul 2020 19:04 - 19 Jul 2020 19:13 #225339 by Scimike
Replied by Scimike on topic Aircon problem
Hi Clutha,
When you start the engine the condenser fan can appear to run, but in this instance it's the viscose fan drawing air through the radiator and spinning the condenser fan. After a few seconds the viscose fan coupling releases, as the engine is cold, and it stops drawing air and the condenser fan stops or slows down.
It's a sign the viscose coupling is working, as when the engine was last "hot" it locked the fan, so you may have just seen air moving the fan.
I believe (not 100% sure) that the Aircon has a pressure switch and if below a set level the the Aircon will not turn on. Well thats how the Toyota MR2 works, so assume the Jimny is the same. When you turn it on you should hear a "click" as the compressor clutch engages, you can also see it happen if you look at the compressor pulley. The centre of the pulley will start to rotate when the clutch is engaged, hence turning the compressor.
Mike
Last edit: 19 Jul 2020 19:13 by Scimike.
The following user(s) said Thank You: Clutha
  • Dal
19 Jul 2020 20:47 - 19 Jul 2020 20:48 #225361 by Dal
Replied by Dal on topic Aircon problem
Not sure if this might help someone but these are my figures from a recent regas, the guy said my system was completely empty when he started. (see attached pic below)
Last edit: 19 Jul 2020 20:48 by Dal.
Time to create page: 0.104 seconds
