Re:Re:JB74 tcase gears
10 Jul 2020 09:30 #224754 by saxj
Replied by saxj on topic JB74 tcase gears
volpin wrote: I can't understand why any of big company don't try or test prev gen gears set to fit on new tcase....worldwide nobody try to install a gears set onto jb74?! I can't believe it. I know some (i'm one of them) change diff gear ratio, 4.56 4.88 5.38.....a big change in hi range gear but nobody make or try something for low range.
Have you changed the diff gearing on a Gen4? If so what was the ratio of the original, and was it a manual or auto?
10 Jul 2020 15:09 #224778 by volpin
Replied by volpin on topic JB74 tcase gears
Mine is manual, original was 4.09, i change to 4.56 and i run 31s
16 Jul 2020 09:34 #225156 by saxj
volpin wrote: Mine is manual, original was 4.09, i change to 4.56 and i run 31s
The 4.09, is that from the documentation, or was it actually calculated from the gears.
What has been published as the final drive doesn't make sense to me, because all the other ratios (gearbox/transmission and transfer) remain exactly the same for both manual and auto, as the gen3.
If it was true, the manual would be labouring along, while the auto would be screaming.
I had someone accidentally put 4.09 in my gen3 manual, it wasn't a great drive with bigger tyres.
16 Jul 2020 12:58 - 16 Jul 2020 13:04 #225168 by mlines
Replied by mlines on topic Re:JB74 tcase gears
Standard ratios for the JB74 are
4.090 manual
4.300 auto
FYI
The other ratios are ( Manual first, Auto second)
1st 4.425 2.875
2nd 2.304 1.588
3rd 1.674 1.000
4th 1.190 0.696
5th 1.000
Transfer 5.151 2.300
Last edit: 16 Jul 2020 13:04 by mlines.
16 Jul 2020 13:29 #225169 by saxj
Replied by saxj on topic Re:JB74 tcase gears
According to the global suzuki site transfer is 1.000 and 2.002 for manual and 1.320 and 2.644 for the auto
16 Jul 2020 13:30 #225170 by saxj
mlines wrote: Standard ratios for the JB74 are
4.090 manual
4.300 auto
Which is completely opposite of the Gen 3.
Time to create page: 0.198 seconds
