Re:Re:JB74 tcase gears
06 Jul 2020 11:28 #224583 by volpin
JB74 tcase gears was created by volpin
hi to all, i'm looking for informations about gears compatibility for JB74 tcase. Do 3rd gen push-botton tcase gears are compatible with JB74 tcase?
i want a reduction gear set for my JB74 but i can't find infos or anything to buy.
thanks for the help
06 Jul 2020 22:45 #224615 by crash486
Replied by crash486 on topic Re:JB74 tcase gears
I've heard that these fit the jb74 but not seen anyone fit them as yet.
protrack.gr/en/gears/jimny-vvt-ddis-reduction-gears
crash486
07 Jul 2020 04:20 - 07 Jul 2020 04:56 #224618 by mlines
Replied by mlines on topic Re:Re:JB74 tcase gears
crash486 wrote: I've heard that these fit the jb74 but not seen anyone fit them as yet.
crash486
I would be careful. The JB74 changed back to a manual system, the VVT was electronic. I am not saying they don't fit, just be aware of the change. Looking at the part numbers between the standard VVT box and a JB74 box, the majority of the gears/shafts are identical. A couple of the parts (e.g input shaft) have a single final digit change (e.g 0 to 1) which in my experience is a minor revision change that can just be a different supplier.
The parts that "connect" the electronic actuator to the "gears" are the clutch sleeves, these appear to be the same. So it does look on paper to be probably compatible if the minor part number revisions are just minor, not consequential, changes.
As a cross refer to the Suzuki parts list, looks like in that kit you get:
Suzuki Part 5 - identical between VVT and JB74
Suzuki Part 10 - 29232-76J11 becomes 29232-76J12
Suzuki Part 4 - identical
Suzuki Part 7 - 29111-84A00 becomes 29111-84A01
Suzuki Part 18 - Speedo drive - varies (probably due to different final drive ratio and tyres.
Sent from my moto g(7) plus using Tapatalk
Last edit: 07 Jul 2020 04:56 by mlines.
07 Jul 2020 05:07 - 07 Jul 2020 05:08 #224622 by yakuza
Replied by yakuza on topic Re:Re:JB74 tcase gears
I have assumed that the transfer case shifter in the JB74 is a more or less direct replacement of the actuator on the VVT Jimny. The shift pattern is not like the earlier shift lever transfer cases so the new handle imitates the push button actuator so to say.
And Suzuki tends not to re-invent everything on a new model.
But then again assumption is the mother of all #¤%!-ups..
Last edit: 07 Jul 2020 05:08 by yakuza.
07 Jul 2020 08:53 #224628 by saxj
Replied by saxj on topic Re:Re:JB74 tcase gears
crash486
Martin, have you been able to confirm what the actual final drive ratios are? What has been published doesn't make any sense.
09 Jul 2020 20:47 #224737 by volpin
Replied by volpin on topic JB74 tcase gears
I can't understand why any of big company don't try or test prev gen gears set to fit on new tcase....worldwide nobody try to install a gears set onto jb74?! I can't believe it. I know some (i'm one of them) change diff gear ratio, 4.56 4.88 5.38.....a big change in hi range gear but nobody make or try something for low range.
Time to create page: 0.228 seconds
