Re:I managed to crack the ABS ring! :)
- Roger Fairclough
- Thank you received: 225
06 Sep 2020 19:41 #227850
by Roger Fairclough
Replied by Roger Fairclough on topic I managed to crack the ABS ring! :)
Hi Hun.
I am thinking of getting a Trailmaster 50 mm lift kit and any comments you can supply on yours would be appreciated.
Cheers.
Roger
Cheers.
Roger
06 Sep 2020 21:33 #227852
by HUN
Hi Roger, I've sent my comments to you in a private message, please check it! Regards, Gabor
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Replied by HUN on topic I managed to crack the ABS ring! :)
Roger Fairclough wrote: Hi Hun.
Cheers.
Rogwer
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
07 Sep 2020 06:50 - 07 Sep 2020 06:51 #227859
by HUN
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
If I were to keep this shaft/setup then I would strip down and weld up the scars instead of filling with adhesive. Then I would get it re-shaped in a lathe with a precision metal fabrication firm. Yesterday I finally decided to go down the route of fitting a full floating axle setup. :evil: It will cost much more than I thought so I need to be careful with my spendings... Luckily I have a second car so I'm not in a rush to sort this out.Lambert wrote: Would it be possible to fill that cut with a 2 part epoxy then you are at least mobile?
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Last edit: 07 Sep 2020 06:51 by HUN.
- Livinti
30 Sep 2020 06:07 - 30 Sep 2020 06:09 #228637
by Livinti
Replied by Livinti on topic I managed to crack the ABS ring! :)
Hi there,
To put it in a nutshell: disappointment continues....
We have changed all parts and assembled both sides "as it is written in the big book", quality parts were used and now ran around 5-6 hundred kms and oil started leaking now from the right side :sick: :sick: :sick:
Now I am speechless, cannot imagine where the problem might be. And it appeared on the opposite side compared to earlier. And now we dis the repair, so cannot blaim any technican that something was not done properly.
Yes, there were grinding marks on the shaft surface and there are new ones that I did cut myself, but they are not going completely through and just for that I have placed sealant on top of the abs ring around the shaft.
Now, we need to find out something else....
But no real idea.
But no real idea.
Last edit: 30 Sep 2020 06:09 by Livinti. Reason: spelling
30 Sep 2020 06:26 #228638
Replied by mlines on topic Re:I managed to crack the ABS ring! :)
Is the axle shaft or the axle casing bent?
- Roger Fairclough
30 Sep 2020 08:11 #228640
by Roger Fairclough
Replied by Roger Fairclough on topic Re:I managed to crack the ABS ring! :)
Also check the axle breather. If it is completely blocked the pressure build up could be enough to initiate a leak.
Roger
Roger
The following user(s) said Thank You: mlines
Time to create page: 4.294 seconds
