Re:I managed to crack the ABS ring! :)
28 Jun 2020 07:46 - 28 Jun 2020 07:46 #224124
by HUN
TrailMaster 2" lift kit
ORE transfer box HD brackets
T-Max split charge system
Flo-Flex castor polybushes
Kumho KL71 tyres
AVM manual hubs
ORA radius arm guards
Push-fit breathers
Replied by HUN on topic I managed to crack the ABS ring! :)
I used brand new parts and did not heat up anything. Bearing went on with relatively small effort (no reading on pressure gauge taken means less than 1t pressure was applied). New ABS collar took 9t load at the end.
Next time I'm planning to cut off the ABS collar again but use the bearing splitter with the press to remove the wheel bearing only. The high tensile threaded bars hopefully can cope with less than one tonne force...will see.
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Last edit: 28 Jun 2020 07:46 by HUN.
- Dano0404
28 Jun 2020 21:52 #224204
by Dano0404
Yes. I work with things like this but didn't seen to make a difference.
Replied by Dano0404 on topic I managed to crack the ABS ring! :)
Lambert wrote: Did you apply any heat to the ring, not glowing but hot like 200c?
- Thank you received: 115
29 Jun 2020 14:13 #224238
by maverick
Jalapeño, IISY?
Replied by maverick on topic I managed to crack the ABS ring! :)
I take it you have a Rear Disc Conversion fitted?
Jalapeño, IISY?
29 Jun 2020 14:38 #224240
by HUN
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
Yes, I have. :woohoo:
Kumho KL71 tyres
AVM manual hubs
Push-fit breathers
- Livinti
26 Aug 2020 13:30 - 26 Aug 2020 14:49 #227367
by Livinti
Replied by Livinti on topic I managed to crack the ABS ring! :)
Hi there,
The question for me still remains, how could the seal, or bearing fail so early?
I have the similar problem. After having the seal and bearing replaced in a garage, giving them the picture illustrated replacement instructions from BigJimny
the oil leakage started in a few weeks... Sometimes life is complicated and had other priorities, so did not return to the garage and drove it for long weeks. No high milage, occasional not heavy offroad. Now removed it with a help of a friend and bearing ring shows play, seal looks also damaged. How could a bearing and/or seal fail in 3-4 weeks?
The built in bearing/seal/retainer was the right quality set from BigJimny.
Now I am also facing the task of retainer ring plus bearing removal.
But fear that there is another problem and leak will come back after building in new material...
Do you have anyidea, where the problem could be? Might be damage on the shaft surface, BELOW the retainer ring surface, letting oil out berween the shaft and the ring?!?
Any experience, suggestion would be appreciated...
Thx in advance!
Thx in advance!
Last edit: 26 Aug 2020 14:49 by Livinti.
26 Aug 2020 16:30 #227372
by maverick
Jalapeño, IISY?
maybe they used too much force to push the ABS Collar on, or it was not on properly?
Where is the Collar "cracked" - can you upload a photo?
Jalapeño, IISY?
Time to create page: 0.193 seconds
