Gen4 replacing diff oil
- Thank you received: 96
17 May 2020 11:27 #222394
by DAGZOOK
Replied by DAGZOOK on topic Gen4 replacing diff oil
Not sure about an oil that meets both GL4 & GL5 specification - it's either one or the other. Both have different properties and for a good reason!
At the end of the day, a Diff is a simple beast. GL5 oil is the industry standard for 99% of diffs. But you'll do no harm what so ever playing it safe and going with a GL4 if you're unsure.. I'm just frustrated with Suzuki because they've been deliberately 'non-committal'. I bet they wouldn't tell you what grade fluids they use at a Suzuki service station... Probably just standard grades out of a commercial drum like most garages....
17 May 2020 18:08 #222437
by Busta
Replied by Busta on topic Gen4 replacing diff oil
The diff in the gen4 is the same as the gen3, which in turn was carried over from the SJ. They are tried and tested, very reliable and there's absolutely nothing fancy about it. Any gear oil will be fine. I use EP90 in mine, which is the gear oil used in almost all plant and agricultural machinery as well as industrial gearboxes. Basically, if it says gear oil on the bottle it will be fine.
- Thank you received: 330
17 May 2020 19:52 #222453
by Gadget
Replied by Gadget on topic Gen4 replacing diff oil
Thanks, it's the curse of working in IT where you frequently need to get precisely the right 'thing' or something else doesn't work. It's a struggle for me to go for a good enough option! :silly:
17 May 2020 20:53 #222457
by Scimike
I believe it is possible, did some googling some time ago to find how such a thing is possible.
If I recall correctly corrosion inhibitors are added to GL5 to prevent possible yellow metal damage, so it's ok in GL4 applications.
So it's a battle of additives. I guess it's not a problem, but like antifreeze anti corrosion additives they don't last for ever, so sticking to a maintenance schedule is probably more important with combined spec gear oil.
So yes they do sell GL4 and GL5 spec gear oil.
Mike
Replied by Scimike on topic Gen4 replacing diff oil
DAGZOOK wrote: Not sure about an oil that meets both GL4 & GL5 specification - it's either one or the other. Both have different properties and for a good reason! ....
Mike
The following user(s) said Thank You: DAGZOOK
- CC Baxter
18 May 2020 04:02 #222464
by CC Baxter
Replied by CC Baxter on topic Gen4 replacing diff oil
I've come across GL4/GL5 combinations in marine applications so they can exist but I haven't used any. Chris
- auchenblae
- Elite Member
- Thank you received: 25
06 Jun 2020 16:14 #223316
by auchenblae
eddie
24 Swift Ultra ALLGRIP
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
Replied by auchenblae on topic Gen4 replacing diff oil
Three comments
1) Busta your comment was econonic in detail, therefore incorrect, to use an oil in a diff the oil has to adhere to the GL5 spec for the high shear stress that the hypoid gears put the oil the oil. Not any gear oil but one with a GL5 rating. A GL4 only spec oil will not be suitable in this case.
2) The GL5 oils has added sulphides to cover for the extra shear stress on the oil. In around 1954 the sulphides used to get the GL5 spec tended to shed sulphar out of solution and may well have dammaged gearbox yellow metals.
Since around 1957 oil blenders have used more stable sulphides in GL5 oils and I ask any person here that disagrees to provide a link to actual tests that show a modern GL5 oil ( made in the last 10 years) will damage gearbox internal.
Not a link to a similar comment that they damage yellow metal but show details of an actual lab test with a count of the yellow metals in the used oil analysis that is higher than a test in a similar gearbox that was run with a GL4 oil.
Hint, you wil not find such a test that produces these results.
In the past few years some companies have started using other additives other that these extra sulphides to obtain the additional properties required to obtain GL5 status while also having a GL4 qualification. Total of France being one. They will not advise the additives they use to make the oil a true GL4/GL5 specifications.
I have used my contacts in Total to try and tease the facts out but no info was given. Therefore yes there are now GL4/GL5 oils that do not have an additional sulphide load.
3) The Suzuki 75W oil mentioned in Jimny 4 handbook is a Suzuki specified 75W/80 GL4/GL5 oil. I assume using these new non additional sulphide additives.
eddie
16 SZ3 gone 25
07 JLX+ gone 16
99 JLX gone 07
The following user(s) said Thank You: CC Baxter
Time to create page: 0.243 seconds
