Split charging system questions
  • JacksonFamily
15 May 2021 20:43 #235063 by JacksonFamily
Replied by JacksonFamily on topic Split charging system questions
Hello long shot this : did you fix the ‘slightly on’ battery charge light (LED)? Mine currently is slightly on whilst running, battery charging fine though. Checked fuses , etc. Perhaps the output from the alternator is broken. Thanks. Jason
15 May 2021 21:06 #235064 by RainerK
The fault might be a defect of the charge controller of the alternator. Often the coals are worn and then they do not have sufficient contact. The charge controller is not very expensive and sits at the back of the alternator. Also a new alternator might be an option.
Time to create page: 0.076 seconds
