Split charging system questions
- RayC
6 years 8 months ago #219641
by RayC
Split charging system questions was created by RayC
- RayC
6 years 8 months ago #219643
by RayC
Replied by RayC on topic Split charging system questions
To clarify it’s the car dash battery alternator light
6 years 8 months ago #219655
by facade
Replied by facade on topic Split charging system questions
If the ignition warning light is on, then either there is a short to ground on the L wire to the 3 pin plug on the alternator. or the alternator regulator is faulty.
There isn't an external regulator is there, for "super fast charging"? I've only ever seen them on boats.
I take it that that display reads between 13 & 14 V when running.
6 years 8 months ago #219669
by zukebob
Replied by zukebob on topic Split charging system questions
Going down the same line of thought as Facade, you might want to confirm that the previous owner didn't convert to a higher amp alternator when he went with the dual battery setup. If he did, and everything else is working properly, then it would likely be the L wire.
- RayC
6 years 8 months ago #219684
by RayC
6 years 8 months ago #219693
by facade
Seems to be working, I'd keep an eye on that voltage monitor and be prepared to buy a new alternator.
Tbh, I'd likely fit an alternator anyway, but I'd worry it was going to fail and let me down, and they aren't cheap.
The dash looks like a late model, so the ignition warning light is an LED, it can't light up if the ignition feed is low due to a bad earth or dirty ignition switch like a bulb can, it must be the regulator pack or a diode in the alternator.
You could try unplugging the multiplug on the alternator and switch on the ignition- the light should not come on, if it comes on dim there is a load/partial short on the L wire.
Time to create page: 0.108 seconds
