Re:1998 Jimny high idle
29 Nov 2019 07:45 #216058
by giacomom
1998 Jimny high idle was created by giacomom
Hi all,
1998 Jimny G13BB LHD with 1600/1700 rpm....... cold or hot does not change anything ...
where is the problem ?
and in this regard, wanting to make a diagnosis, where the diagnostic socket is ?
thank you
Giacomo
thank you
Giacomo
- Thank you received: 661
29 Nov 2019 10:34 #216063
Replied by DrRobin on topic 1998 Jimny high idle
Hi,
My Jimny starts up at about 1600 rpm, but soon settles down even on cold mornings. It might be the O2 sensor (pre or post CAT) which is faulty.
The OBD-II socket is under the dash board near to the steering column. and bonnet release.
OBD reader will tell you if it is the O2 sensor.
29 Nov 2019 13:32 #216067
by giacomom
Replied by giacomom on topic 1998 Jimny high idle
Thank you DrRobin,
but you're talking about your Jimny which is from 2011 ..... and I think a little different.
Giacomo
Giacomo
30 Nov 2019 14:49 #216090
by kirkynut
Replied by kirkynut on topic 1998 Jimny high idle
Sounds like the Idle control valve or a vacuum leak.
Yours is OBD1. There is a reader in existence for your engine but there's another way I don't profess to know as I've a twin cam on OBD2.
02 Dec 2019 09:12 #216146
by giacomom
Thank you kirkynut
I also think of the IAC, but where is the diagnostic socket (monitor coupler) located ?
Giacomo
Giacomo
05 Dec 2019 12:28 #216256
by giacomom
Up
no one knows where this diagnosis socket (monitor coupler ) is ?
thank you
Giacomo
thank you
Giacomo
Time to create page: 0.605 seconds
