Gen 3 clutch problem
- JackBates
03 Sep 2019 20:28 #213091
by JackBates
Replied by JackBates on topic Re:Gen 3 clutch problem
Cheers guys? And rough cost of it does turn out to be a worn clutch? Just want to see if it's worth the punt as the rest of it is solid!
Sent from my Nokia 7 plus using Tapatalk
03 Sep 2019 20:30 #213092
Replied by mlines on topic Re:Gen 3 clutch problem
I have seen quotes for £180 upwards for a change
- JackBates
03 Sep 2019 20:33 #213094
by JackBates
Thanks again for the help! Reckon we'll take the gamble!
Replied by JackBates on topic Gen 3 clutch problem
Okay, not bad then!mlines wrote: I have seen quotes for £180 upwards for a change
04 Sep 2019 08:34 - 04 Sep 2019 08:37 #213108
by facade
As the clutch wears, the plate thins, and the release bearing moves outwards, so the biting point gets higher up the pedal. You have to lengthen the cable by shortening the outer sleeve to compensate for wear.
Sounds like the inner cable is miles too long. It may be the wrong cable, there may be a gap between engine & gearbox (unlikely) the release bearing might be the wrong one, or collapsed somehow. The cable fixing at the pedal box might be wrong/damaged and the cable isn't in the right place (I can't remember if someone said their cable pulled through the bulkhead on this forum). The cable could be on the verge of breaking, and have stretched massively as the strands break - the broken strands would jam in the sleeve, so it could be that.
Something I used to see on Triumphs, and I know beetles suffer, is crankshaft thrust bearing wear, the crankshaft moves forwards as you press the clutch, and the timing chain and drive belts pull it back. You can see the front pulley move forwards when someone presses the clutch. Never heard of it on a Jimny though.
There isn't usually enough adjustment on the threaded part of the cable to get the biting point at the bottom, even with a brand new clutch.
Most likely just needs a new clutch cable.
Replied by facade on topic Gen 3 clutch problem
JackBates wrote:
90% of the travel was floppy with no action on the clutch and no sort of resistance. The last 10% is stiff and have to jam the pedal into the floor to disengage the clutch to change gear.
Last edit: 04 Sep 2019 08:37 by facade.
The following user(s) said Thank You: JackBates
- JackBates
04 Sep 2019 09:37 #213117
by JackBates
Thanks facade,
I've come from the classic watercooled vw scene but have done my fair share on aircooled bugs and the likes so i know this problem well.
was just checking to see if this is a 'normal' or heard of occurrence on jimnys or not. did feel like the old clutch cable on my mk2 golf before i replaced it but wasn't sure it there was any adjustment on the cable and if so if it was manual or self adjusting ect. couldnt see a clutch MC but thought worth double checking in case i was being dumb!
We've taken a gamble on the it and if the sale goes through then ill sling a new cable in and adjust up to see if that solves the issue!
Time to create page: 0.237 seconds
